Question about Kettler Treadmill Track Motion
Kettler track motion
Whe does the kettler treadmill track motion stops working soon after startup
I have a Kettler Olympic 7892-000 treadmill that has just stopped working.
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 31, 2016 | Kettler Exercise & Fitness
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
Treadmill KETTLER PACER - dc6 system fault, what I
Check if the drive motor is working
Power cycle...if still do not function calibrate or call 877-805-1030
Aug 10, 2013 | Kettler Exercise & Fitness
Error 51 Treadmill Kettler Track Performance
this a problem with the elevation motor. You are working with the treadmill without put in level.
You need LUBE the gear+shaft see the picture. But most importante adjust the POTENTIOMETER a little see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com or www.kettler.co.uk
Jul 17, 2010 | Kettler TX1 Treadmill with FREE INSIDE...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Kettler Treadmill Track Motion Logo
93 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven Brandon
Steven Brandon
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
