Question about Garden
Need to find a replacement 46cm blade do you know as to where i can purchase one for a sovereigen 375 pretrol mower
These are readily available at http://www.espares.co.uk/
Hope this Helps
Posted on Aug 21, 2009
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
Where can I purchase replacement blades?
Hi Jim, you can buy replacement blades for your riding mower at most hardware, or lawn and garden store. I believe Sears home and garden has them also. They are the same as a regular push mower blade, but smaller because you have 2-3 blades. I'll put a link to help you out. All you really need is the model of your mower, and blade length.
Sears com
Aug 17, 2015 | Garden
What kind of blade do I need for a 22 murray hp quantum 6.5 push mower?
Take the old blade with you when purchasing a new one and compare them. That's what I do if I don't know.
Mar 31, 2015 | Garden
Remove base plate on a 375 sprint
do you mean the sump pan? if so just remove th engine from the machine remove the blade boss.undo all the sump bolts( think they are 3/8" ) and remove the sump pan,simples !!
Feb 25, 2015 | Garden
Champion 375
Self propelled mechanism is at fault. Possible the belt has become unattached. Leave engine off and check underneath by the blade. May still be there.
Jun 25, 2013 | Garden
Can you please convert 188cm x 46cm into feet for me please
No, since cm x cm measures an area, while feet measures length. To get an area, you will need ft^2.
188cm x 46cm is 8648 cm^2 . One foot is exactly 30.48 cm, so this is about 9.31 ft^2.
Jun 15, 2011 | Office Equipment & Supplies
I NEED THE SIZE OF THE BLADES OFF A 46 INCH DECK THREE BLADE SYSTEM IT IS A POWER KRAFT LAWN TRACTOR I NEED THE SIZE OF THE LAWN MOWER BLADES
This is a part number.46 inch (three blade) 18 HP TMO 3400005A
MTD makes these mowers.You should be able to use those part numbers to purchase replacements.You can find online at the mtd web site,or Lowe`s and wal mart sell those,or at least some of those parts.
May 12, 2011 | Computers & Internet
I am trying to remove 4 blades from the Sprint 375 Rover mower. they are unmovable, have not been changed for a long time. Please help me!! I am in despair. Des
remove cutter disc from pto
hold blade in vise and weld the blade bolt head to blade on the grass cutting side using welder ( this transfers heat to threads and helps ) then undo nuts while still clamped in vise
repeat for other blades
always use new blades , bolts , nuts and washers
cheers pauly46
Sep 10, 2010 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
