Question about Mackie Thump 15 TH-15A Powered Speaker
There is no sound coming out of the speaker I have power but no sound what do you think is wrong?
The woofer doesnot work and the horn is working but not as usual
First you need to verify that there is nothing wrong with your amplifier. Simply swap speakers around and see if the fault follows the faulty speaker or stays on that channel. If the speaker is at fault I would hazard a guess and say, that the woofer has burnt out and is now a high resistance. This would then increase the total impedance of the speaker circuit and make the horn speaker sound the way you described. This can be verified with an ohm meter. Total impedance should be about 4 to 8 ohms. The only real remedy is to replace the faulty speaker woofer. Sorry
Mar 07, 2015 | JBL EON 15-G2 Powered DJ Speaker With EQ...
WHAT WOULD BE WRONG IF A PAIR OF YAMAHA NS-10M HAD NO SOUND COMING OUT, WOULD THEY COST MUCH TO FIX
Hi.
I don't think both speakers are damaged unless, some kind of electric failure affected them, they just must be connect in the wrong way.
Aug 27, 2011 | Yamaha NS-10MT Speaker
No sound coming from both speaker
There are several things that could be wrong:
Your speakers are broken
Your speakers are not turned on
The sound cable is plugged into the wrong jack
The speakers are muted in Windows
The sound drivers are not installed or are corrupt.
Your sound card is bad.
Lots to think about. First ask if your speakers were working. If so, when?
Try a system restore back to when they were working. That should fix it. IF not, proceed:
Go into the control panel and click on sounds.
Select system sounds, choose a Windows event that has a sound assigned and try to preview it. If the preview arrow is grayed out, then the sound drivers are at fault. If you have a black arrow and you click on it and it seems like it's playing, then check for mechanical problems.
If Windows thinks it's playing and it isn't, the system restore thing should fix it. Or try another set of speakers to see if your speakers have failed.
Apr 17, 2011 | Computers & Internet
Creative Inspire 5200 system won't work
Hi. Check your speaker system with a different audio device like iPod or any MP3 Player using the same jacks. If the speaker system gives out sounds then nothing is wrong with it... if no sounds come out, then you know what I mean...
Try to replace the speaker of your sub-woofer... maybe that can fix it!
^_^
Jun 06, 2010 | Creative Labs Inspire 5200 Computer...
There is no sound comes from my computer,speakers are good,there is no mute.
Just to be sure, boot up your laptop and go into the BIOS. I think by pressing F10 it should take you into the BIOS.
Reset the BIOS to factory default in there, save changes and exit.
After it gets into windows, see if you have sound, if not then reinstall your sound drivers for the laptop.
If after that you still don't have sound then that means there is no power coming out of the power connector for the speaker wires and that means the motherboard would have to be replaced.
May 31, 2009 | HP Pavilion dv6000z Notebook
Sound coming out of wrong speakers
I know nothing about your model but the very first thing that I would do is to pull the power cord from the wall outlet for at least 10 minutes and then plug it back in. This may reset everything.
Apr 15, 2017 | Pioneer VSX-D608 Receiver
Power, but no sound coming from my speakers, checked fuses.
i have power but no sound it worked fine for a little while yesterday but it stopped whats wrong wit it
Mar 04, 2008 | Onkyo HT-SR700 System
Speakers set up properly, but no sound from PC
I have set up Koss desktop speakers properly (I think) -- they are plugged into the power outlet, plugged into each other, and plugged into the CPU of my computer. But there is no sound at all coming out -- just silence.Can You Please Help Me
Oct 16, 2007 | Koss HD 50 Computer Speakers
Mackie Thump 15 TH-15A Powered Speaker Logo
37 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
