Question about Sharp Computers & Internet
How to unplug ecm on 3406e - Sharp Computers & Internet
I have a 1998 peterbilt 379 with cat motor its showing code 3406E with code 55 can you help me
it will be a special cat code so find a cat dealer and have it deciphered.
Jan 24, 2015 | Cars & Trucks
I have a pete with a 3406e cat. if the jakes or out of adjustment can it drop oil pressure
highly unlikely, the jakes are just valves in the cylinders that open to let the compression escape the piston cylinder so the engine stops producing power and can slow down your engine much quicker than normal. They have nothing to do with your oil system. If you have low oil pressure my first guess would be to look at and test your oil pump.
Nov 06, 2014 | Cars & Trucks
How do you replace a ecm module on the 1998 dodge ram diesel 2500?
You can find a ecm at autozone but if not you can find one at the dealer, make sure that you handle this part with care, also make sure the ecm is ready to install, you need this things before installing the ecm latex gloves, you also need to ground your self to prevent any shock with ecm by doing this you need a wire with the one end to the ground of the car and the other end to your self you can buy one at autozone, NEVER TOUCH ECM WITH OUT GLOVES this is a very sensitive and delicate part, unplug the negative cable from battery then unplug all the wires from ECM unscrew the ecm and replace the new one, screw the new ecm plug in all the wires and connect the negative cable that's it your done good luck!!!!
Sep 27, 2014 | Cars & Trucks
Location of ECM and how to change ECM.
passenger side Under dash on the side kick pad with 3 connector
To replace it .. unplug battery then remove connector at ECM on old ecm remove two screw and the plate remove both memory and install them in the new ECM....plug 3 connectors and battery cable
hope it help
Sep 14, 2014 | 1992 Buick Century
How does water is getting into oil on a 3406E catpiller engine
Water gets into any engine either from a hole or a head gasket. Usually a head gasket will go bad and leak coolant into the cylinders and down into the oil pan. Since it's probably a diesel, you probably won't be able to check for or notice if it's puffing grey smoke. that's a sign that your head gasket is bad.
Nov 08, 2013 | Motorcycles
How do I install fuel injectors on a 3406E Cat
This Should be done at a dealer or by someone experianced.
There are several special instructions that have to be followed
as well as a special injector height tool required to set the injector.
Jun 05, 2010 | John Deere Ar50041 Diesel Fuel Filter 3020...
Remove dashboard from honda accord S/W
I don't think removing the dashboard will help much. All the 1995 Accords I've worked on the ECM is under the right front carpet. Take a look and see if your is the same.
Disconnect negative battery terminal. Remove right door sill molding. Pull carpet back to access ECM. Remove ECM cover screws. Unplug ECM connectors. Remove mounting screws. Remove ECM.
Mar 17, 2010 | 1995 Honda Accord
Where is the ECM located on a 1993 Isuzu Trooper?
If you don't have a coil pack working, unplugging the ECM will do nothing to reset the coil pack. If you have power present at the plug, you need a new coil pack.
Jul 28, 2009 | 1993 Isuzu Trooper
'89 chvy 3500 454 Drive-ability
engine control module probably shorted out. unplug wire harness to ecm and sniff for electrical burn smell....if present then you know the deal...gd luck chris
Jun 18, 2009 | 1989 Chevrolet Suburban
Computers & Internet Logo
108 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
