Question about Candy Refrigerators
What is the correct number on the dial - Candy Refrigerators
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
Our HP Office Jet 4255 all in one suddenly won't receive faxes for some reason. It has been working fine up until now. We can send faxes, but for some reason the phone just keeps ringing and won't...
CHECK THE TELEPHONE NO.
Verify that you are dialing the number correctly. (i know its funny to ask)
Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
TRY DIALING FROM THE FRONT PANEL
manually dial the number from the front panel of the fax.
If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
Check the connections
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP OfficeJet 4255 All-In-One InkJet...
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
Dial tone problems, when i press on hook dial and dial the number the dial tone keeps and the number won't dial
Sounds as if the phone line from the wall is not in the correct jack. The correct jack should say "L" or "line" not "T" or "aux"
Jun 30, 2009 | Dell Office Equipment & Supplies
Trying to fax but message says no answer
If its dialing some numbers then its unlikely to be a hardware issue - make sure that the numbers are correctly specified, with the correct area code, international prefix etc and that (if needed), the option to dial a number for an external line is set correctly.
Thanks.
Jun 04, 2009 | Dell 1600n All-In-One Laser Printer
Are one touch dialing board not working
When sending, try using a analog phone, and dial the number you are calling. Make sure it is the correct number. You might hear someone pick up the phone, or you will get a recording messege. This will tell you if the phone is the correct number you are trying to dial. When you are finished, plug in the phone line back into the correct jack on the fax machine.
Once you hear the dial tone, your phone is working.
If you can send a fax, and the machine does not send it, then the machines fax board might not be working.
There are other questions I like to ask about the phone line. Are you using a adaptor to convert the analog signal to digital? If this is the case then the adaptor may be causing some problems with your faxes.
Good luck.
Feb 27, 2009 | Xerox WorkCentre Pro 765 Laser Printer
Can't dial abroad
how are you dialing the number on the phone, what is the number, if your are not dialing it correctly it will cause this,
i.e i believe austria is 00 + 43 + Area Code+ Tel #
and norway is 00 + 47 + Area Code+ Tel #
if you go to www.countrycodes.com this will help
Jan 01, 2009 | Lands Phones
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Refrigerators Logo
21 people viewed this question
Top Candy Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
