Question about OKI C3400n Laser Printer
How do i install oki 5800 on windows8? - OKI C3400n Laser Printer
Windows8
There are also books available. some are in PDF format. One is called "Windows 8 Secrets".
Apr 13, 2013 | Samsung Computers & Internet
I can't access or upload data on my Iomega device since my upgrade to Windows8... any solutions out there please?
Your Iomega device requires drivers and I think that they will work with Win7 but not the obsolete Win8 version. Return to your old OS to enable it to work.
Jun 16, 2017 | Iomega Computers & Internet
My lifecam 1.4 how can I get it to work with windows8
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 06, 2012 | Microsoft LifeCam VX-3000 Web Camera
It's oky to format many times
Its okey to format your phone many time. But it will erase all the content that your have in your phone(contact, message, and installed software.program that are not included when you bought it).
I suggest to use nokia ovi suite I think but not sure to back up your data in your phone before formatting it and restoring it after you've formatted it. Please make sure you remove the memory card when formatting your phone.
Nov 04, 2011 | Nokia 5800 XpressMusic Smartphone
I NEED TO INSTAL OKI B2540 MFP PRINTER ON MY
You can go here
http://www.oki.co.uk/support/printer-drivers/index.aspx
May 18, 2010 | OKI B2540 MFP Printer
How to reset drum for the oki B410DN
Most of the OKI printers have a fuse installed in the drum to do the reset. If you google the drum reset kit you can find the drum kits and fuses.
Jan 14, 2010 | Office Equipment & Supplies
Oki 5800 shows 177 fatal error
A 177 is a fuser code. The fuser is the part that gets hot. Try rebooting the printer. Try taking it out and putting it back in (with the machine off). You might need to replace the fuser unit.
Jun 08, 2009 | OKI C5200n Laser Printer
OKI C3200n and HP LaserJet 3052 Can't be in the same PC
You do not say what operating system you are using?. They are both compatible with Windows 10.There should be no conflict between the two printers. Use system restore and go back in time before you had the problem. Disable your antivirus and try and install them again. That should work.
Jun 26, 2017 | OKI C3200 Led Printer
OKI 3200CN with Vista Laptop
make sure when you install you opt for USB port driver.
if already installed, uninstall, then reinstall
OKI do not support this printer very well for vista
Sep 29, 2008 | OKI C3200n Led Printer
OKI C3400n Laser Printer Logo
26 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
