Question about Frigidaire GLEQ2152ES Electric Dryer
FEQ1442ESO Trimmer keeps going off before it should
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that the timer on your Frigidaire dryer, model# FEQ1442ES0, keeps going off before the time is up. I suggest either contacting the manufacturer or your local authorized technician. Either will be able to assist in resolving the issue of your dryer not running the full cycle. Hope this is helpful.
-Best regards-
WP
Posted on May 16, 2014
How do you know if the heating element is bad for a FEQ1442ESO
If you get a voltage reading at the two terminals where the heater element connects up to, then the heater element is defective.
Nov 22, 2015 | Dryers
Lights blink and turns off
Hello friend, thank you for your post!
From what you have described the light on your Frigidaire dryer blinks and then shuts off. Which light are you referring to? If you could provide a little more information I could assist you further. -Matt
Mar 12, 2015 | Frigidaire Dryers
How to change out controls for feq1442eso dryer
Assuming this is the real problem, it is not hard to do. Remove the facing and simply replace wire for wire and connection for connection.
Feb 03, 2013 | Dryers
Frigidaire dryer FEQ1442ESO RUNS BUT NO HEAT
This looks like a plain Jane westinghouse dryer I worked on a bit back. I did a video:
How to restring the heater pan:
MORE HERE
Sep 16, 2012 | Frigidaire Dryers
My husband got a 18"
1. There is probably a hook type affair on the back of the trimmer that you are supposed to route the extension through to keep the plug from falling out.
2. I would never do what I am going to tell you for safety reasons. It is possible to get a piece of cord, a tie wrap or a hose clamp, adjust it to fit over the trigger and around the handle so that when you pull the trigger, you slip this tight fitting device over it and it keeps it held in tightly enough so you don't have to keep your hand on it. Be advised that this is dangerous in that if you drop the trimmer or hit the electric cord, the trimmer will continue to run uncontrollably until you can get to the power, slip the device off of the trigger or the trimmer cuts the electric cord.
It can be done, but as you can see, it can be very dangerous. These things can amputate fingers.
Gary
Jun 22, 2011 | Vacuums
My Frigidaire FEQ1442ESO Dryer Keeps beeping (6) beeps at a time & turns itself off after running only 18 seconds so I cannot dry anything and the only way to stop the beeping is to unplug it, do you...
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this LINK to access service videos for your machine.
Sep 30, 2010 | Frigidaire FEQ1442ES Electric Dryer
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I feed string into my Homelite Mighty Lite 26ss grass trimmer? I don't have a manual and I can't figure it out. Thank you!
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 03, 2010 | Homelite Mighty Lite Lawn Trimmer
Frigidaire electric dryer feq1442eso melted bracket new bracket doesn't have the same colored wires. Need schematic for wiring.
There should be a schematic inside of the back panel or inside the control panel(where timer is)
Feb 22, 2010 | Dryers
My ryobi trimmer keep flooding.It has a Walbro carb #wt539 in it.
The most likely possibility is that the carb needs rebuilding. Just cleaning may not help. Gasgets go bad over time if fuel is left in the trimmer.
Nov 11, 2008 | Ryobi 15" Electric Factory Reconditioned...
Frigidaire GLEQ2152ES Electric Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
