Question about HP OfficeJet 6210 All-In-One InkJet Printer
I have a new computer and it has windows vista on it and I need a new disc to upload and use my scanner. New install program for vista. How do I get a new install or program disc.
  • 240 Answers
Ya u do need a new disc u can download it from many websites
Posted on Jun 23, 2009
I have a canon canoscanD646U. I lost my installation disc so I downloaded the drivers needed to get it working again. It now appears in my devices section. I however have no program to actually scan...
this is what your going to do.reformat your computer in to a operating system thaw will fit with your specs.for my opinion much better you install a win7.so your computer will be updated for new applications.
Feb 25, 2011 | Canon CanoScan D646U Flatbed Scanner
Tip
How to Install Window XP with Vista
If you wish to install Windows XP on a computer that comes with Windows Vista already installed then you will have to create a separate partition on your hard drive to install Windows XP onto. This effectively splits the hard drive into two, and keeps the different versions of Windows separate. To do this you need to open up the Computer Management screen by going to the Start menu and then right-clicking on Computer and selecting Manage.
From the Computer Management screen select Disk Management, right-click on your main hard disk where Windows Vista is installed and then select Shrink Volume. This opens up a window where you can choose how large you want the new drive partition for Windows XP to be. You need to select the size of the new partition carefully, as you will need enough space to be able to install Windows XP successfully (around 10 gigabytes) whilst leaving enough space for Windows Vista. After you have selected the appropriate amount of space click on the Shrink button to begin the process, and once that has completed you should be able to right-click on the new partition (which should be labelled “Unallocated free space”) and select New Simple Volume.
Follow the on-screen instructions to configure the partition, set a drive letter (such as E:\), give it a meaningful name such as “XP”, and then restart your computer. Whilst your computer reboots, access the BIOS and change to boot sequence to boot from your CD/DVD Drive before any other device, insert your Windows XP installation disc and then save and exit from BIOS. You will then be taken to the Windows XP installation program where you should follow the instructions until you come to the screen asking you which partition to install Windows XP to.
Make sure you select the new partition and not the one with Windows Vista installed, as this will cause problems. Once Windows XP has finished installing, you will notice that Windows XP loads up automatically, rather than giving you the choice of which operating system to use. To rectify this insert your Windows Vista installation disc and restart the computer to access the Windows Vista installation program. From the Install Now screen select Repair My Computer, and then select your Windows Vista installation and then Startup Repair. You will now be able to choose which operating system to use when your computer starts up.
on Dec 07, 2009 | Computers & Internet
Have favorite publishing suite....easy and old....but now not compatible with my windows 7 system....what can i do to fix and have my new computer upload my cd: PrintMaster Gold Publishing suite Version...
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Jan 10, 2011 | Computers & Internet
HP 4470c flatbed
If you can get the software onto your computer, try right clicking on the scanner program--properties--compatability tab--check "run this program in Xp compatability". Worked for me in Vista
Jul 06, 2009 | HP Scanjet 4470c Flatbed Scanner
Unable to install scanner
Cant find such a scanner, are you sure of the model "performance", If it is not Vista compatable, ie if Epson have not released a Vista driver, then it is not going to work with Vista.
See Epson web and download driver if available, if not change scanner or operating system or purchase software
Check your Epson product CD to see if it already contains Windows Vista drivers. If the CD indicates support for Windows Vista, follow the instructions that came with your Epson product to install your driver and other software.
If your Epson CD does not indicate support for Windows Vista, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR WINDOWS VISTA COMPUTER because the setup program is not compatible with Windows Vista. Instructions for installing additional software from your CD may be available with your driver download.
Note: If you already have ArcSoft PhotoImpression™ 5 installed on your Windows Vista computer, you may need to install a "patch" program. Go to the ArcSoft website to download and install the patch.
Products that are not Vista compatable are not capatable with Vista, who would figure hey!!
Jan 23, 2009 | Office Equipment & Supplies
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
I just got a new computer with windows vista.my old computer was windows xp .i have a hp psc 1315v scanner printer copier.all in one series,my old disc wont get it running wiyh this program.how do i...
hp.com, click drivers and downloads, then enter the model number then download and install your drivers using the add printer wizard, have disk tab. good luck!
Sep 23, 2008 | HP Office Equipment & Supplies
HP PSC 2350 Printer/Scanner & just purchased a new computer (Windows Vista) & the discs I have for this printer/scanner only support Windows 2000, XP not Vista.
You can set compatability to windows 2000. I presume you have vista. start menu. control panel, programs... then you will see set compatability or similiar (my control panel won't open at the moment). use the wizard to walk you thru the steps. select the program you are having issues with. It will allow you to run the program as win 2000 compatability.
Robert
Aug 27, 2008 | HP Office Equipment & Supplies
Installing software for new canon digital camera
Apparently Windows Vista does not require the software and worked without installing it. Regards Trish
Jul 28, 2008 | Canon COLOR IMAGE SCANNER
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
