Question about Samsung WF328AAW Front Load Washer
Where is hall sensor located on samsung wa456drhdsu/aa 01
2001 saturn lost keys to it. Got it to crank cut right back off secrity lights on bought a brain box for it and got 2keys with it. Still want crank I need to know what to do t could the box be bad ..
No ,the box is probably not bad , but you need to have it programmed . The dealer is the only one that can do that ? The keys don't matter .
The passlock sensor mounted to the ignition switch assembly is located inside the upper right side of the steering column. The passlock sensor contains two hall effect sensors: a tamper hall effect sensor and a security hall effect sensor. The tamper hall effect sensor is mounted on top of the security hall effect sensor. Should someone attempt to defeat the system by use of magnetic experimentation, the tamper hall effect sensor will activate first.
The passlock system is a vehicle theft deterrent system which deters drive-away vehicle theft by disabling engine operation if the ignition lock cylinder is not rotated with the proper mechanically cut key.
The passlock system is made up of an ignition switch assembly, passlock sensor, body control module (BCM), instrument panel cluster (IPC), and a powertrain control module (PCM).
The ignition switch contains a magnet mounted on the lock cylinder and a passlock sensor assembly which consists of security hall effect sensor, tamper hall effect sensor, and output resistors. A drill proof metal shield is also staked over the sensor housing.
The BCM has the passlock controller integrated into it which controls the majority of the security systems logic. The BCM reads the data from the passlock sensor continuously. If the data is correct and has been received by the BCM within a specified time, the BCM will send a coded password to the PCM. The PCM will then allow the fuel injectors to operate.
The coded password for the security system is sent from the body control module to the PCM via the class 2 data link. If the password is correct and received within the specified time, the PCM will allow the fuel injectors to operate.
Sorry but you can't just replace parts , you need to know how the system works . You need to take this to a ASE certified repair facility that knows how it works .
Oct 10, 2015 | Saturn Cars & Trucks
I have a 94 ford taurus and im looking for the crank position sensor location. i have the pulley off and dont see it by the crankshaft.
"1994 Taurus crankshaft position sensor (CKP) location:
3.0L regular engine: Hall Effect switch inside distributor.
3.0L DOHC SHO engine: CKP sensor is located on the front of the cylinder block just above the crankshaft.
3.0L FF engine: CKP is at 10 o'clock position of crankshaft pulley.
3.2L DOHC SHO engine: same as 3.0L SHO engine.
3.8L engine: Hall Effect switch inside distributor "
I copied the above info from another site. So if your vehicle has a distributor, then it should have a Hall Effect switch inside the distributor.
Jun 08, 2014 | Kent Moore S- Tool J-37089 Crankshaft...
Maytag front load washer mah9700a
I am not used to this appliance as I am from the UK however:
As hall sensors are used on direct drive machines the hall sensor is located on the back of the drum underneath the big round metal motor part, this will need to be taken off to gain access to the hall sensor. (this is how it works with the LG hall sensors as they are also direct drive)
Apr 05, 2014 | Washing Machines
8E error code on samsung top load direct drive washer
Samsung has us replace Mems sensor, main harness and user interface board. They do not have away to test the mems sensor in the field.
Dec 09, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Cannot find the crank shift sensor location
M112 And M113 Engines
  1. Before servicing the vehicle, refer to the precautions.
  2. Remove air filter housing.
  3. Remove hot film mass air flow sensor.
  4. Remove air duct housing.
  5. Release and disconnect electrical connector at crankshaft Hall sensor.
  6. Remove bolt.
  7. Pull crankshaft Hall sensor out of crankcase.
    CKP sensor location
To install:
  1. Installation is the reverse of removal.
  2. Tighten crankshaft Hall sensor to crankcase bolt to 6 ft. lbs. (8 Nm).
  3. Carry out first initialization and then sensor rotor adaptation using Star Diagnosis tool.
Oct 22, 2010 | 2002 Mercedes-Benz C-Class
Samsung washer wf218anb/xaa has code dc and wont spin clothes they are still wet
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Mar 03, 2010 | Samsung WF337AA Front Load Washer
Samsung front load washer keeps getting E7 and E3 what is this?
E3 - MICOM is attempting to drive the motor but is not getting any
response signals from the hall sensor. Visual check shows
motor is not running. (Locked, Defective Hall Sensor or
Overload)
Im not locating an E7 error. Did you mean 7E?
This information may or may not relate to your washer since you did not provide a model number.
Nov 25, 2009 | Samsung Washing Machines
Washing stops after a min or two & LE flashes up!
This is caused by an error from the hall sensor on the motor. It is possible that one of the connectors has come loose (this is an issue with LG's or it could be the hall sensor it's self is bad. First check that the harness that connects to the motor is tight. If that doesn't help then the hall sensor will have to be replaced. The hall sensor is located on the motor. The hall sensor basically tells the computer which direction and what speed the drum is turning.
Nov 16, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Replacing hall sensor
The hall sensor is located in the back of the washer.  You need to get through the back panel to get to the hall sensor.
Jul 11, 2008 | LG WM-2277HW Front Load Washer
Samsung WF328AAW Front Load Washer Logo
70 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
