Question about Symphonic ST420FF 20" TV
How do I hook my DVD player into the Symphonic 20 flat
I hook the dvd player into the front of the tv on the audio and video inputs (white and yellow) and no matter what channel I put the TV on I just get snow. Any idea of what is up? I may just be hooking the cables into the wrong part of the dvd player itself, but regardless any help is appreciated. Thank you
4 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Audio sound but no video
if you had hooked up everything correctly check your wires probably they are defected.if you had done that check your tv the video circuit maybe defected.you can also try another tv or dvd and see what they do good luck
Posted on May 14, 2007
  • 41 Answers
SOURCE: connecting dvd player
the tv should be in video mode in order to accept input from dvd...when it does'nt work try to use a modulator that should be connected at the back through using cable with f-connector both sides...
Posted on Sep 03, 2008
ekcnoel
  • 998 Answers
SOURCE: I am trying to hook
try to look first the video in commonly the color is yellow, white, red the yellow one is the video and the white,red is the audio if you connect it press the video on your remote.
Posted on Oct 12, 2010
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
I am trying to hook up a dvd player to my Symphonic TV. (ST420FF) When I hook the red, white and yellow cords to the back of the dvd player, I can't find it on the tv. I don't see a line in or line out...
Oct 12, 2010 | Symphonic ST420FF 20" TV
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
How do i/can i record tv to a DVD ]
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Jun 19, 2009 | Symphonic WF803 DVD Player/VCR
I have a dvd player that I am trying to hook up to a sharp tv model number 25L-M100B. This tv don't have the necessary ports inthe back to plug dvd or anything up to it. It does have 2 in the front of
Hook the dvd player up to the front inputs usually a yellow and a red or possibly a yellow red and white depending if the TV is stereo or not.
Then on your remote, it the INPUT button and take it to "VIDEO 1" while your dvd player is on and you should get a picture.
Make sure not to mix the cable colors.
Yellow is video
White Audio
Red Audio
A lot of times there is only either white or red and not both. This is just Mono sound, it works, just not "stereo" sound.
Jun 01, 2009 | Televison & Video
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Televison & Video
Connecting dvd player
Sep 02, 2008 | Symphonic ST420FF 20" TV
Symphonic ST420FF 20" TV Logo
20 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
