Question about Toshiba Satellite M35X-S311 Notebook
Screen not Working
My screen is not working. It will cut in and out seems like there is a loose connection b/c once you jiggle it the screen will work again.
  • michaeldidow Jun 23, 2009
    I meant move the cover that contains the display back and forth like I was going to close and open it
  • Curtis Brown May 11, 2010
    By jiggle do you mean that you pick up the conputer and shake it up and down or do you move the cover that contains the display back and forth like you were going to close and open it? I suspect that you interface cable is loose or damaged and these questions will help indentify where. Thanks
    Scholar:
  • 36 Answers
Ok,
The back and forth motion indicates that the problem is in the interface wiring. Below is a link to disassemble the computer display screen and expose the interface wiring cable:
1) disassemble the lcd screen: http://www.irisvista.com/tech/laptops/ToshibaM35X/Satellite-M35X-display-1.htm
Follow the instruction step up to step 5, do step 5. Now look into the right side of the trough
exposed by removing the keyboard securing strip. There will be a silvery looking cable with a white plug on the end of the wire to the left. The white connector must be pushed completely into the white socket on the motherboard. Use a pair of heavy non cutting tweezers or needlenosepliers to push the white connector into the socket. You can turn the machine on and see if it is improved. If it still is not correct proceed to step 7 and stop following the dis-assemembly.
The flat cable that runs across the LCD panel must be connected fully into it's terminator connector. If the cable will wiggle from side to side using a gentle motion then the cable must be reconnected. Examine the connector that the flat ribbon wire is inserted into. There will be one little ear protuding from each side. You must pull the ears in a rocking motion toward the cable. Use a blunt thin device, like a paper-clip with a rounded end. You may have to use two of them, one keeping one side from moving and the other to push it's ear down. When the two ears are down CAREFULLY pull on the ribbon cable. If it does not move STOP. Try moving the ears in the opposite direction, if they move continue until they are fully loose. If they do not move continue. Again try to CAREFULLY pull on the ribbon cable. Assuming that the ribbon cable is loose, re-insert the ribbon cable into the ribbon cable connector. Keep the ribbon cable square with the connector. do NOT push hard, the cable will stop at the bottom of the connector port. When the cable is in the connector you will use the blunt thin device to push the little ears of the locking bar back into lock position. Now reassemble the unit to step 5. You can turn the machine on and see if it is improved. If it still is not correct, please advise.
I hope that his helps.
Posted on Jun 23, 2009
  • 4 Answers
Try not to repair it mannualy as it may void any warranty try giving it to the service center
My screen is blank but camera still seems to work
If all functions are working, there is a problem with the screen or the ribbon wire connected to the system control board may be loose. Replacement screen may be required.
Mar 13, 2012 | Olympus Stylus 790SW Digital Camera
My screen keeps blacking out, we actually have to wiggle the screen until it shows the desktop...after a day of that, we now can't get the screen to work. I have held my fingers on the hindges and the...
The fault may be a broken ribbon cable that connect the screen to the motherboard. Less likely is that the connector is loose on the motherboard. The connectors are normally very well seated and don't normally come loose.
One thing that you must do, is that if you can get the screen working, even once, save all your important files and pictures onto an external device, such as a USB stick.
Jan 14, 2018 | ASUS Eee PC 1000H Laptop
The lcd screen not working
The screen is defective or the cable that connects the screen with the board seems to be loose soldering it may resolve the issue.
May 12, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Super Nintendo picture flashes in & out on my flat screen
Check your cables and connection, they could be worn or cracked, try using on another tv or use a different device in the same plugins to verify if what is wrong
Dec 04, 2009 | Nintendo Super NES Console
Screen goes green jiggle the screen and it clears up
tienes un problema en el la cinta flex de tu lapto tambin puedes tener soldadura fria
Aug 24, 2009 | Compaq Presario M2000 Notebook
Hp dv5000 half screen gets stuck and blurry
It is recommended that you replace your screen.
Mar 17, 2009 | HP Pavilion dv5000t Notebook
Only have half screen on my Dell Inspiron 1501
What your describing is a failure of the LCD or possibly the inverter cable connection to the LCD. Most likely an LCD replacement will be required.
LCDs run around $150 on Ebay
Jan 25, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
Dec 31, 2008 | Dell InspironTM 1501 Notebook
Compaq presario 1700 LCD issues
i have the exact same problem. try connecting the laptop to an external VGA screen. if it works, then the problem is most likely a loose cable (connector). It turns out that the connector (which connects the motherboard or gfx card to the LCD screen) on my laptop is torn and cut. see if u have the same problem. this link might help u check out ur problem:
http://www.laptopparts101.com/lcd-screen-video-cable/
Nov 21, 2008 | Compaq Presario 1700 Notebook
Ps2 turns on but no images
try jiggling the av cable connecting to the ps2 in its place.
Jun 28, 2008 | Sony PlayStation 2 (PS2) Console
Toshiba Satellite M35X-S311 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
