Question about Kettler Treadmill Track Motion
Why does kettler track motion stops working after 3 minutes
I have a Kettler Olympic 7892-000 treadmill that has just stopped working.
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 31, 2016 | Kettler Exercise & Fitness
Error code e11 I have kettler track motion , treadmill stopped working what do I do
Reset the treadmills, disconnect the power for 30 seg. or reset the small switch to the side of power button. and try again.
However you must RUN the software calibration for e11. and fix it
go to the HOOD cover motor, and follow the steps .
God bless you
Sep 30, 2013 | Exercise & Fitness
Error 51 Treadmill Kettler Track Performance
this a problem with the elevation motor. You are working with the treadmill without put in level.
You need LUBE the gear+shaft see the picture. But most importante adjust the POTENTIOMETER a little see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
MY TREADMILL STOPS JUST A MINUTE AFTER STARTING.
Try Lubricating the belt with silicone spray.
Probably the resistence from the belt scraping over the ground board is too high, forcing the machine to switch off in order to prevent damage.
Jul 24, 2009 | Kettler Exercise & Fitness
Stopped working
Try a self test...Flip the unit upside down on the ground, tracks 'up towards the sky' and trun it on. It should run for about 30 seconds during which it will cycle through various track and impeller motions.
If it completes the test, try it in the water again.
If not, contact us at www.arrowmotor.net for service arrangements or parts. You can also try Maytronics direct at www.maytronicsus.com.
Jun 01, 2009 | Dolphin Maytronics Diagnostic Robot...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Mar 29, 2009 | Kettler Exercise & Fitness
Kettler Treadmill Track Motion Logo
Top Kettler Exercise & Fitness Experts
ray gallant
Steven Brandon
Steven Brandon
todd
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
