Question about Whirlpool Refrigerators
Strong smell coming from back of unit
There is strong smell coming from back of unit. It emits the odor when the fan is running and it is a pretty rotten smell. We have moved the unit out and it does not appear as if anything is back there causing the odor and there is no rotten food inside and there is no smell inside. Your help is appreciated. Russ
  • 351 Answers
Hmm, usually when i go to a call like that i find a remainding body of a mouse or rat, they try to make it to the pan underneath for water and get chopped, other than i would clean EVERYTHING....
Posted on Jun 23, 2009
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
Strong Odor when running
The smell is coming from the condenser heating up which should be located all around the outside of the box. When it is in pull down from being warm the condenser will get very hot and the smell would be the spray foam and any other chemicals in the vicinity heating up. When heated up to a certain point they will off gas and you may get a smell. After a little wile the smell should go away for good.
Mar 27, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Bad smell from heating system
I would guess so because there should not be an odor coming from your vents and if it is worse when the heat is on there's a chance something literally crawled up there and died! I always wanted to say that not referring to peoples butts. lol But all kidding aside. You would be surprised at the little critters that can find there way into your venting system. Or just organic material that has gotten in there somehow and decayed. Best of luck tracking down those oderiferous emanations.
Dec 20, 2013 | Eagle Vision Cars & Trucks
Old frigidaire wall oven model RBE-94N emitting strong odor & not baking
Hello - From what you have described it sounds like the unit has faulty elements or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
Nov 10, 2012 | Frigidaire Ovens
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator Smell
remove grill. pan will not come out ( leave it in place ) took an empty liquid dish detergent botlle of bleach and water squirt into pan let it sit - scape if needed . then take a wet/dry vac - repeat)
I will let you now if the odor is completely gone
Oct 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Chemical odor...
from where does the smell come?
inside the unit or from the body?
does the smell spread to food items?
Jun 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
257 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
