Question about ASUS Computers & Internet
0x80300113 Attempt that an usb recognizes and the PC cannot
I Nee to fix a error 0x80300113
Dial Toll-free +18002044427 and get right solution to fix Error 0x80300113 error codes, Our Expert technician ready to help 24*7 hours..
Apr 18, 2017 | Computers & Internet
Usb flash memory not recognize and become hot temperature malfunctioned
At first attempt in plug in your usb flash memory didn't recognized you may plug out. And plug in again until it recognized you may see that theres an icon in the task bar at right below. Thanx
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hello i have a problem with my external hard drive (320GB western digital), when i'm connect to my PC..the windows does not recognized it and said malfunction device.How can i solve it? Need help nooriz
Unplug all USB devices that may be connected. Then do the following.
You can attempt a repair of the USB system by opening The Device Manager and
removing all of the USB devices. Then reboot the computer, that should cause
Windows to reload the USB drivers from the dll cache
Nov 14, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
May 23, 2009 | Canon PIXMA MP620 All-In-One InkJet...
My sony nwz-S616F doesnt transfer songs from pc
check in your windows explorer folder and open it there
Dec 03, 2008 | Electronics - Others
E270 isn't recognized by windows; can't enter recovery mode
Are you running Vista? shame on you for not checking to see if your player is compatible with it
If you are running XP:
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 01, 2008 | SanDisk Sansa e270 MP3 Player
Windows XP will not recognize Brother HL 2040 Laser printer
you could try this: unistall the HP printer driver first, uninstall the brother driver , restart pc, load brother driver with the usb cable unplugged from printer. Software will prompt for the cable to be connected to printer
Apr 10, 2008 | Brother HL-2040 Laser Printer
Dosent recognize the usb port
what are you connecting? Name of the device, manufacturer....what is your operating system XP?
answer those and then we can see if we can help you.
Have you tried other USB ports? Other computers? was there software that came with it? did you attempt to load it?
Jan 03, 2008 | Adobe Photoshop 7.0 for PC
Canon PowerShot SD600 - Problems downloading images - same as below
did you download the canon download app or are you using the installed pc generic camera download app? it will make a diference if the computer cannot reconsile which too use. let me know and we can go from there
Jul 04, 2007 | Canon PowerShot SD600 Digital Camera
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
