Question about Lexmark X1240 All-In-One InkJet Printer
Paper misfeeds, more on one side then the other
I have a all in one X1240 and the paper keeps feeding from the right side first coming out crooked.
  • 390 Answers
Hi
this mostly occurs due to either major dust accumilaton or paper peices being stuck to the paper feed rolls
try and clean the rolls with some spirit and this should start working fine again
hope this helped
cheers
Posted on Jun 23, 2009
Misfeed- cleared, but still says misfeed is there
Hi
1st when using transparency paper U must set up the printer propreties to paper kind U use.
for now do the sim. 30 -1 to see hows sensor is detected bi touche
Jun 16, 2014 | Sharp MX-2700N Color Copier
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
My copier ( Sharp AR 201 ) , causes misfeed every time I try to make a copy. I have tried all the trays , including bypass tray. But it didn't work. I guess it gets jammed when it goes up to the fusing...
If the rollers are old and dry they can cause a misfeed.
When they are dry; paper is less likely to be pulled into position for printing. If a feed roller is slick on one edge, the apposing side may direct the paper on an angle (somewhat sideways) and a crooked alignment results in paper being caught up in the gears, wrapped around rollers, torn in pieces, etc. Check the roller surfaces.
Jan 12, 2018 | Office Equipment & Supplies
Lexmark x1240 Feeding incorrectly/crooked
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 29, 2010 | Lexmark X1240 All-In-One InkJet Printer
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark x1240 printer / scanner
I don't have a 1240 printer but we have had this problem. Usually we just align the paper and there is usually a movable piece that keeps the printer snug and aligned. Usually we move it right at the edge of the paper. This usually prevents the paper from crinkling. If this doesn't work I would guess that one of the rollers is not working. But my guess is more of the paper guide that you need to move so that the paper stays aligned when it goes in. Let me know if this helps.
Nov 14, 2008 | Lexmark X1240 All-In-One InkJet Printer
Misfeed on lanier 7320
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
Apr 23, 2008 | Lanier 1205 Copier
Lexmark x1240 Printer
Please adjust the paper guides and check the paper rollers for any abstructions...
All the best.
Regards
Mohammed
Nov 02, 2007 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
