Question about Ovens
Jes1033wb 001 microwave says lock and will not turn on but light works
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Conbi microwave oven and grill grill and oven working microwave not warming up light on and turn table working as normal
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Basic
    Microwave Oven Troubleshooting Tips
    heatman101
    Mar 05, 2011 | Ovens
    Microwave has power...light lights and turn table turns but nothinng heats up and there is a smell of burnt electrical items
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Nov 19, 2010 | KitchenAid KEMC378KSS Electric Double Oven
    Have to replace my hotpoint RVM1335WC 001. Need size, watt info
    depending on age of microwave it could be 650watt,& 1.5cuft.
    Sep 28, 2009 | Ovens
    Light goes off and on by itself
    I have the same problem with a DACOR ECS 130 and also set the breaker panel switch to OFF to prevent the light from turning on-off or staying on. It might help to unplug the touchpad connector behind the control panel or it may be a problem relay on a circuit board. I've had the problem for several years but will start work on it tomorrow because we do not bake often at my house.
    Bill (bsquared37@yahoo.com)
    P.S. I'm not an appliance tech but have had problems with the DACOR DM024 microwave( made by SHARP) and the DACOR raised vent. I think DACOR products are junk. The raised vent problem required replacing the entire circuit board!
    Aug 30, 2009 | Dacor ECS130 Epicure Electric Single Oven
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Kenmore oven locked
    Hello dktshopping,
    I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
    Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Microwave oven stopped working
    This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
    Aug 27, 2008 | Ovens
    Ovens Logo
    20 people viewed this question
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
