Hot to interface symbol p470 - Computers & Internet
Me pide password de bios y no lo tengo es una GETAC P470
Antes de todo remueve la batería de la computadora, luego abajo en la laptop hay una tapadera que tiene dibujada una batería redonda, sostenida probablemente con un tornillo philip, quita el tornillo y cuando veas la batería redonda como de reloj quítala con cuidado y dejala afuera 5 minutos luego vuelve a ponerla y pon la tapadera y la contraseña de la bios ya no debe pedírtela.
Jun 23, 2011 | Getac Rugged Notebook P470 PC Notebook
Cab't get computer/application to recognize the scanner
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11585&sliceId=&dialogID=227820981&stateId=1%200%20227814895
This unit is only supported by Windows 2000 or Windows XP environments.
Regards,
Dan
IT Professional
May 04, 2011 | Symbol P470-SR1211100FB Handheld
Is there a driver for barcode scanner i am holding Model No - LS1902T-1000 company - symbol tech inc. hotsville n.y.
The barcode scanners are usually using ans Standard PS/2 or USB interface in the same way as keyboard, therefore you dont need an driver.
You would probably need to setup the barcode scanner according to the used connection/interface.
Here is the manual for yur scanner http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=189660311&stateId=1%200%20189654341
Jul 08, 2010 | Symbol LS2208 Handheld
It can work with adapter usb i don't have ps2 port in my computer
The LS 4000i is available with several different interfaces.
LS4004i - RS-232/Serial interface
LS4006i - Keyboard Wedge interface
LS4007i - USB interface
Oct 12, 2009 | Symbol LS 4000i Handheld
Symblo Scanner not pairing with Base
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
Jun 01, 2009 | Symbol P370 Handheld
Frozen. Yellow light on, Buttons appear to do nothing.
Holding down the Enter key on the keypad for 30 seconds forces the scanner to reset. It is called a forced power down.
May 26, 2009 | Symbol P470-SR1211100FB Handheld
Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Jun 27, 2007 | Symbol LS2208-7AZK0100S Handheld
Computers & Internet Logo
David Payne
David Payne
