Question about Merit Fitness 715T Treadmill
Tips to replace motor - Merit Fitness 715T Treadmill
Rear window has no power to it
you need to get a voltage tester or multitester to check the supply voltage to the rear window motor which sould be about 12 volts.To get access to the motor you need to open the facia cover of the rear door.Locate the cable going to the motor, then if you can see the connection to the motor put one end of the multitester pronge (red tip one) to the motor cable connection. Put the other multitester pronge (black tip) end to the metal part of the door. The black tester prong tip should touch a bare metal part of the door ,not a painted surface cause electricity cannot flow on painted surface, usually on a hole with screw on the hole.On the motor side you should touch the bare metal part of the motor cable connection with the red tip pronge of the tester. If the multitester registers 12 volts then you got power supply. check cable connection to the motor , and the connection of the motor body to the rear door to see if its tight enough. If it does not work then its the motor that needs to be check or replaced.
May 19, 2013 | Cars & Trucks
Tip
Central unit fan motor replacement tip: Blade removal
All of my tips have been tampered with. I deeply regret I must remove the content from these tips. I will not write another tip for fear of further tampering of my literature. If you have any questions I am on facebook.
JW Webster
on Jul 14, 2010 | Heating & Cooling
Tip
Replacing motor/transaxle mounts on 87'-98' Cadillacs
First disconnect negative battery terminal. raise vehicle on hoist or jack stands. My tip is to use a 15mm distributer wrench to remove mount nuts . I found that this tip wil save you time during replacement. Service Manual procedure says to remove belt and Air conditing compressor.Good luck with this tip. Be patient . Note: Tip was shared with me by An ASE Certified Tech.
on Dec 31, 2009 | Cadillac DeVille Cars & Trucks
Car doesnt idle normal after engine gets warm
could be dirty or defective spark plugs! remove spark plugs (engine cold) and try cleaning using a motor cleaner and remove those carbon deposits at the tip. also examine tips for corrosion. if the tips are worn out, time to replace those plugs. the manual recommends to replace spark plugs every 10,000 kilometers.
May 05, 2011 | Toyota Corolla Cars & Trucks
Can't get the 4 motor to housing bolts off sp 1515-z-1 esc pump motor without twisting bolt into. have broke one as of now. Trying to replace pump seal. instructs say to remove 4 motor bolts to housing and...
Thank you for posting your question here on Fixya.com.
As a rule, when we get those pumps in for repair and the bolts are breaking you notice the motor shaft is severely corroded as well. Often times that will make the unit unrepairable as the new seal won't hold up on a damaged motor shaft. If that is your case you will want to at least consider a new motor and seal for the pump.
If you can remove the bolts with or without breaking you can precede to attempt the repair. Bear in mind you will need to get the busted tips out of the pump housing in order to install the new bolts. That is not an easy task as you are working with a small brass bushing in a thin plastic leg. The removal easily damaged the pump housing. Try to work the bolts back and forth to free the tips. You will then need to get the broken tips out. If all goes well and the shaft is not too bad you should be ok. Anything goes wrong, replace the motor and seal and you'll still save some $$$ compared to a whole new pump.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 12, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
How to replace a electric motor for power window in 1994 honda accord
How to Replace a Window Regulator (with Motor)
(DIY Complexity: Moderate / DIY Time: 2.8 hours)
Parts:
1. Window Regulator
Tools:
1. Screwdriver
2. Trim Panel Removal Tool
3. 3/8 in. Drive Ratchet
4. Socket Set
5. Riveter Kit
Steps:
Step 1 Remove the door panel by removing the handles and switches. It is required to unscrew or unclip the panel.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
o Tip: Refer to the vehicle specific service manual if available. There are several fragile plastic clips and hidden screws on the door panel that will break if removed improperly.
Step 2 Remove the vapor barrier.
Step 3 Disconnect the glass from window regulator.
Step 4 Tape the glass to door frame. The glass should not require removal.
o Tip: Tape the glass out of the way to allow access to the window regulator and window lift motor assembly.
Step 5 Disconnect the electrical connector from the window motor.
Step 6 Remove the window regulator mounting bolts. Slide the regulator assembly out through the interior access opening of the door. Remove the motor.
Step 7 Attach the original motor to the new window regulator and install the regulator assembly. Tighten the mounting bolts.
Step 8 Reconnect the electrical connector to the window motor.
Step 9 Install the window back onto the window regulator.
Step 10 Re-install the vapor barrier.
Step 11 Re-install the door trim panel and handles/switches.
Step 12 Test the power window for proper operation by rolling the window up and down in complete cycles for proper testing.
o Tip: After re-installing a window lift motor and regulator, it may be necessary to re-program it following manufacturer specific instructions. Not following or performing this step may result in improper power window function.
Hope helps (remember comment and rated this).
Jun 18, 2010 | 1994 Honda Accord
Our horizon LS760T treadmill just started making a clicking sound from the motor. It appears to be coming from the sawblade at the end. Looks like it isn't straight and could be bent slightly... would this...
Get a flashlight and what you described as a saw blade is the optical wheel.When the motor is turning their is a optical speed sensor that the wheel travels between it. Without starting the unit move the belt manually and see if the wheel is hitting the optic sensor. If it is then usually their two allen screws that hold the wheel in place loosen them and try to center then wheel or gently try to straighten the wheel teeth. Then start the unit up and if the clicking is gone you've fix it.
If the clicking is their then using a flat tip screw driver and touch the ends of the motor with the tip the place your ear on the handle and see if the clicking is coming from either end of the motor, if the clicking is located on either end of the motor could be worn motor brushes replace motor brushes or failure of the bearings replace the motor. If motor is good then proceed to the front roller place the tip on the stationary shaft and listen to each end of the roller if the clicking their replace the front roller.
May 27, 2010 | Exercise & Fitness
I have a 2005 Kia Armanti, im trying to replace my spark plugs, I can see 3 of them. the other 3 I have no clue, can you please help me??
If it is the 3.5 motor, see my "Tip" on replacing the plugs on a Kia Sedona. That tip is for the 3.5 liter motor.
May 17, 2010 | 2005 Kia Amanti
Want to replace motor brushes...any tips on this
I need to also, so please post what you learn. I found several examples for other WMs on YouTube (search brushes carbon washing machine) Note, I was able to get my Bosch Axxis WFL 2060 spin working again with the following quick carbon dust cleaning trick:
1) Unplug WM and tip up to a 45 degree angle and then safely stabilize so you can safely access motor from bottom. No need to take off back or disconnect motor.
2) Using a small tool like a 1/4 allen wrench or medium screwdriver start tapping repeatedly (for 2 mins) on the brush holders, and back metal clips that connect to the brushes, your just moving the dust around really.
3) Next using an alcohol damp cloth clean the motor commutator - on this motor it is easily exposed on one of the sides 90 degrees away from, and in line with brush holders. Hold cloth on commutator and turn motor, this will also make it clear if commutator is damaged. You cloth should be pretty dirt after 2-3 rotations.
Repeat 2 and 3 above a few more times cleaning up all the carbon dust off the commutator and around the brushes.
After that tip down and test again. A more thorough cleaning could be done by removing brushes and cleaning em - but this will buy you a few weeks/months of operation.
Sep 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Microwave oven
Check first the motor coupling under the turntable, if that is not the problem , then test and eventually replace the turntable motor.
Click here and select model to get parts and diagrams.
Nov 01, 2008 | Emerson MW8777W Microwave Oven
Merit Fitness 715T Treadmill Logo
22 people viewed this question
Top Merit Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Merit Exercise and Fitnes Expert? Answer questions, earn points and help others
