Question about Garden
Kawasaki strimmer strimmer runs for 30 seconds after priming then stops and womt start again its a kawasaki td40
chad7houston
  • 62 Answers
SOURCE: ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Posted on Oct 08, 2008
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
  • 3 Answers
SOURCE: My lawnboy 10304 runs about one minute and shuts down. Any ideas?
It sounds like it is 2 stroke.
Carefully remove the carb bowl, by undoing the brass bolt.
Examine the brass bolt for a small pin-hole in the side.
Use a piece of corn-broom NEVER anything else !!! and poke the hole(S) to make sure they are clear.
Blow out with air if available.
You can use this method to clean out all the carb orifices carefully.
Hope it helps,
Andy.
Posted on Jul 16, 2009
mowerman1857
  • 389 Answers
SOURCE: My engine will start then die
Remove the float bowl from the carburetor, clean it out and use a commercial spray carburetor cleaner to clean out the main jet in the center of the carburetor where the bowl nut screws in
Posted on Sep 19, 2009
  • 15 Answers
SOURCE: I have a weedeater series 300 lawnmower. When I
thats a common problem with those briggs motors. There is a plastic tube that goes from the back of the carb to the other side of the motor. There are two small bolts that hold the tube down opposite the carb end of the tube. They loosen over time allowing to much air to get in. Also the tube cracks but not to often. If that doesn't help you need a kit that comes with a gasket and a diaphram. you may need that because the tube warps were it meets the carb. That should fix it.
Posted on Apr 22, 2010
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
How to adjust idle speed on kawasaki td40 brushcutter ?
Most idle speeds on brushcutters/ trimmers are controlled by a small screw that touches the plate the cable pulls. Screwing it in holds the throttle a bit wider open and the idle goes up accordingly
Feb 25, 2013 | Motorcycles
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
My keurig b70 coffee maker says prime. sounds like the pump works for awhile then stops. prime lights up on the screen and doesnt let me do anything else why
Mine would brew the first cup fine, then the pump would run but would not draw water from the reservoir. I turn it off, turn it back on it would draw water for one cup then would not draw water again. I unplugged it waited 30 seconds and plugged it back in, assuming that would reset the electronics. It worked fine following the PDPU (power down, power up) procedure. Simply turning it off will NOT reset the processor, you MUST unplug the unit. Remember to wait 30 seconds or so prior to plugging the unit back in.
Nov 28, 2011 | Keurig Platinum B70 Coffee Maker
I have a 2006 Kawasaki concourse that will start but wont Idle with out the choke on. Seem to run better if the the fuel stop **** is on prime but it still wont idle. Whats causing this?
You may want to have your fuel system checked out. You may have water or trash in there. Have you checked you air filter? Fuel filter? Does the bike run fine other than the idle problem?
Mar 08, 2010 | 2006 kawasaki Z 1000
Homelite vacuum blower doesn't run at full speed.
Sounds like you need to adjust the Carb. Take the two plastic caps off and turn each screw 1/2 turn. and then try to start. If it works then out the caps back on (or you can leave them off, they are not needed).
Aug 03, 2009 | Homelite Consumer Products MightyLite...
94 camry won't start after running out of gas?
Fuel injected vehicles will need to be primed when they run out of gas. Your going to have to turn the key on then off at least twenty times leaving it on for five seconds. You may need a half to full tank of gas to get the pump to prime. Another way is to get some carb cleaner, and while an assistant is cranking the vehicle, spray one second then quit for a second then repeat and get the car to start that way and just keep it up until it runs rougher or smoothens out, and let it idle for at least a minute to purge the air out of the system. The key is easier, unless you can figure the relay and bypass the relay to run the pump for at least 30 seconds. That should get it running again.
Jul 17, 2009 | 1994 Toyota Camry
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
