Question about ATI RADEON 9200 Graphic Card
Problem my monitor show many red, blue and green dotted vertical lines.. never had a problem like that until now since i changed my graphic card
So the screen just did this when you changed graphics card? That means there is either something wrong with your graphics card to which you changed, the resolution is set too high, it is not seated all the way, or you have it on the wrong connection. If it is a DVI port make sure your monitor is set to DVI (digital) connection. If it is a VGA port make sure your monitor is set to analog connection.
Posted on Nov 04, 2007
Blue vertical lines
Hi, I am sorry you are having issues with your graphics card.
Yes the oven trick does work but it is only temporary and you will have to do that process over and over until the card just all out quits responding. Once a GPU begins to display multicolored or blue lines across the monitor its time to put it out to pasture so to speak.
Aug 31, 2013 | MSI NX8800GTS-T2D512E Geforce 8800 GTS...
Dotted lines on laptop screen
This not good, hook a spare monitor to the video output usually on the back, if picture okay! the LCD panel on the laptop will need to be replaced. But if both show the same symptom the video graphics card is bad normally built into the motherboard.
Apr 17, 2012 | Sony VAIO VPCyB13KXS AMD DualCore...
The left side of my laptop screen wet all white with red green yellow blue lines running veretical lines running through it. looks like someone spilled paint on it
Vertical lines are usually caused by 2 things, either your graphics card is going bad or your screen is going bad. How you check if it is your graphics card is by plugging it into an external monitor (if you have one).
If the lines still appear on the external monitor then you know its the graphics card going bad, which isn't probably worth fixing these days if you take into account how must laptop pricing has dropped.
I hope this helps.
Best of luck!!
Mar 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have vertical lines on screen I have changed the whole screen assembley but lines are still thers , exactly in same place
Hey There,
The reason this happens is because the graphics card is either loose burned out or jsut needs to be cleaned... to clean it use a pencil rubber in the gold tips that connect it, blow on the card to remove any dust build ups and reconnect the graphics card when done (make sure its clipped in properly).... different brands of computers will do different things such as the different coloured lines and screens flashing red. My dell latitude 630 had green and blue verticle lines. Just follow what i said and it should be fine
Hope this will help you in Resolving the issue with the vertical Lines on the screen.
Feb 14, 2010 | HP Compaq nx6325 Notebook
Vertical lines on monitor I have a dell dimention 8300 computer with a 128MB DDR ATI Radeon 9800 pro graphics card. Yesterday when I turned on the computer, I had 5 sets of vertical lines on the flat panel...
by process of elimination, try unplugging your monitor from your computer. turn it on, the built in self test should run. it will give you color coded boxes like red green, blue etc.. and would tell you no signal. if you cant see any lines during the buit in self test, then is the video card thats busted...
Hope it helps!
Feb 07, 2010 | Computers & Internet
that might actually be a bad LCD..
or bad graphics chip..
either way probly cheaper to buy a new laptop.
alternatively you can just connect a CRT monitor to the monitor out port.
Jan 09, 2009 | Toshiba (5105-S701) Graphic Card
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
Vertical lines in lcd
sounds like your graphic card is bad, try first to download updated drivers from the internet and see what happens, also try to connect an external monitor and see what happens.
Mar 02, 2008 | IBM ThinPad R51 (2887EXU) PC Notebook
ATI RADEON 9200 Graphic Card Logo
175 people viewed this question
Top ATI Computers & Internet Experts
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
