Question about Coleman Powermate Powermate 5000W Generator
Motor runs fine, but no electricity to outlets
My husband thinks it is the brushes. It was working fine, then when we went to use it again, it wouldn't work.
    Sergeant:
  • 384 Answers
Try turning the switch to "ON" for the power output.
Posted on Jun 23, 2009
Won't start after running fine
You tested it on other outlets? Check the motor for reset button?
May 02, 2013 | Karcher Garden
Change motor brushes on Fein vacuum
If the vaccuum was used with large amount of fine dust , most times the filters are largely shut beaten ,beware also of the electric field look its color to get a indication of the expectation of the remaining running time of the motor. 80% chance by use of fine dust the motor can better be replaced instead of replace brushes because the brushes are in a short time again shorted because of 1 collector in the armature , or get an equivalent motor if you can get FIXAPART motor or a original replacement if the remainder is still in reasonable condition.
Some brands of vaccuums uses the same motor could be sometimes an option because of the price.
Sep 07, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Hi. I have a hayward lx. The problem is we turn it on and it works fine. A while later, though, we are finding that it has shut itself off. The circuit breaker is not tripping. I first thought it was the...
First is it plugged into a GFCI outlet? is that what you reset when you said you reset the outlet? Could be moisture in motor or wiring, or could be motor beginngin to ground out. Most motors have an internal thermal overload. If the motor is getting hot, it will shut down until it cools, then it will restart.
Jun 21, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
My Oreck vacuum cleane won't turn on
I have an Oreck vacuum. My son used it just earlier today and it worked just fine, then just a little while ago a tried to turn it on to vacuum our bedroom and suddenly it won't turn on! I tried plugging it into other outlets but it was no use. My husband takes a look at it and first thinks that the switch is out in it. He takes the handle apart and quickly realizes that it is not the switch that is causing the problem. Then he took the base of the vacuum apart, removes the spin brush part and cleans it off, puts it back together, and suddenly it works! He said that when those brushes get real dirty the motor gets clogged, then it just won't turn on. I'm just happy I married someone who can figure these things out, because even if I knew the problem I'm still no good with a screwdriver, taking things apart and putting them back together again. Hope this works for your Oreck too and it's running again for you soon.
Jun 18, 2010 | Oreck XL2200 Bagged Upright Vacuum
Drum will not turn.... belt is fine.... I don't think I'm getting 240 volts to the motor.... but don't know why
and you know the belt is fine because?
Do the rest of your electric devices work? Check your outlets ... several of them ... with a volt meter. If you are universally around 117 volts, it would be a surpirze if you are not getting operating voltage at your dryer.
Please check the belt again
Nov 03, 2009 | Roper REX4634KQ Electric Dryer
Our motor on our Kenmore top loader is starting to spark. a while ago all of the motors surroundings started breaking off so my husband put some black electrical tape on it and it worked fine. the other...
dont waste your time cobbling it together get a new motor, their expensive,but sooner than you think the repair wont last and you'll have to disassemble unit all over again,
Aug 25, 2009 | Washing Machines
Hotpoint BHWM129. Cannot change brushes.
there are no brushes in that kind of motor
Aug 16, 2009 | Washing Machines
Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Mar 08, 2009 | GE S8000E
Coleman Powermate Powermate 5000W Generator Logo
428 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
