Question about Hotpoint Dishwashers
I have a hotpoint aquarius dishwasher model FDF784, it keeps showing A01 error code, whats it mean.
SOURCE: Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Posted on Jan 12, 2010
mc1bean
  • 3053 Answers
SOURCE: i need a manual for hotpoint dishwasher model
Hello, michael
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
SOURCE: Hotpoint aquarias fdf784, dishwasher, showing
Hi, I had the same fault, first check the feed or drain isn't blocked, you can do this by pulling the machine out and disconnecting the inlet pipe and checking the filters in the end of the pipe and the dishwasher inlet. Then check the drain still works. Take the drawers/baskets out, remove the drain pipe, get a bucket for the drain pipe. Then get someone to add water into the bottom of the dishwasher and wait for it to drain out of the drain pipe (the drain will need to be at a lower height than the bottom of the dishwasher for gravity to work, it is no longer pumped because you turned it off before all this didn't you :) !)
If it drains fine then its not the drain at fault. If it doesn't you'll have to unblock that pipe somehow, you may have to follow the procedure to unblock the pump below.
If it drained then its most likely to be the pump thermistor/ fuse/ overheat cut out.
You will need access to the bottom of the dishwasher.
Drain it first! and have towels ready.
Tip the whole unit forward onto its door, use one towel to protect the facia.
There is then an access panel at the base of the machine.
using a thinnish screwdriver you can un-clip this at the bottom of the panel and withdraw the panel upward and outwards, you should then see the internals of the machine (wires, pumps, programmers etc.) Where the drain pipe passes inside the machine it will then continue to the drain pump, a small pump with a connector with 2 wires on it (mine were blue but I cant vouch for yours) pull out the rest of the drain hose, it is just pushed into the pump. Stick the corner of a towel down the pump outlet to drain as much water out first.
This pump can be removed by rotating it towards you after you depress the small clip which prevents this happening, be careful the wires are very short and dont give much room for this, (it would be better if you could disconnect it but it is very fiddly! be confident in what you are doing or leave it)
The pump should then withdraw to the right, and the reason for the over heat should be obvious (the pump was jammed on mine by a small piece of chipped plate, the size of a finger nail) the pump may also be a little warm. Do NOT poke anything sharp down the pump outlet to clean it as there is a diaphragm which acts as a non return valve there which is very delicate.
In true Haynes manual fashion........ re-assembly is the reverse procedure.
Good luck, hope it helps.
PS I am not a dishwasher mechanic, I am a pilot, but quite confident at DIY, mechanics and electrics etc so think before you do anything, and disconnect the appliance from the electricity, electric shocks hurt, LOTS.
Posted on Dec 02, 2011
  • 195 Answers
SOURCE: where is the thermistor heater fuse on a Hotpoint Aquarius FDF784
The thermistor is attached to he deposit door see that it the wires are still attached , i have seen where the wires have come off due to closing the door too hard, if they are still attached replace it , to get to it turn off power then remove all the screws on the inside of the dishwasher door , about 20 or s when you lift the door you will see wires attache dto the soap dispenser door , check all wires for conection going to the door , this is a cheep easy fix
emissionwiz
  • 76673 Answers
SOURCE: hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Posted on Jan 18, 2012
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius fdf784 door won't close think it's the hinge gone
suggest fix hinge or contact supplier for replacement.
Sep 18, 2016 | Hotpoint Washing Machines
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Hotpoint aquarius dishwasher tablet dispenser not working
Jan 18, 2012 | Hotpoint Dishwashers
Where is the thermistor heater fuse on a Hotpoint Aquarius FDF784
Dec 02, 2011 | Hotpoint Dishwashers
How do i find the float switch for a Hotpoing Aquarius FDW70
Open the DW. Look in the front right or left corner of the tub.
You will see a plastic dome.
The float switch is directly underneath the dome.
Remove the toe kick plate and located the float switch from the bottom.
Sometimes they get stuck.
Jiggle it then try the wash cycle.
If that does not work, replace the float switch.
Feb 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
21 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
