Question about Refrigerators
Kenmore coldspot 106.58736800
Ice maker just stopped working. Tray is not filling with water and red light on the side control panel is flashing. The filter is most likely old so I pulled it to order a new one but the water dispenser is still pumping out water just not the ice maker. Any suggestions?
ctf1800
  • 4402 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Posted on Dec 08, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Posted on Mar 06, 2009
  • 10865 Answers
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
  • 1218 Answers
SOURCE: Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 25, 2010
Kenmore coldspot ice maker not working
check to make sure the water hasn't frozen in the tube that it should fill the tray with. Please let me know if this isn't the problem and I can further assist you. If frozen, you should thaw out the freezer to get it working again.
Good luck
Apr 11, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
I have a coldspot kenmore
Tim,
At first blush it sounds like the water valve that supplies water to the ice maker is sticking or leaking and letting too much water in.
If you can, watch how much water fills into the ice maker tray (very boring stuff). If it overfills the icemaker tray, then the water valve or timer is malfunctioning and needs repair or replacement.
Apr 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dec 08, 2007 | Refrigerators
Ice Maker Not making Ice
Water is in the tray and you have freezing temps? Can you tell me a little more? The flashing red light began when the ice tray filled and did not freeze? Let me know when possible, Thanks JT
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
