Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Integral FlashPoint 3Dx Lite drivers - Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
MY MONITOR VIDEO RESULT IS VERY BAD. WHAI IS BEST SETTING FOR NVIDIA GFORCE6150LE
I have no problem with 1440x 900. I can watch HD video. This video adapter I used with linux Ubuntu - up to 10/10, than MInt - up to 13. But under linux I could not watch the HD video(only under W XP). I am not expert on linux so maybe someone other who is expert has set up the linux better :)
I could play operation flashpoint, mafia, Empire earth on lower details.
Sep 09, 2011 | Nvidia GeForce 6150 LE
2 D-cell maglite bulb lights up only when I press it down after removing lense. Everything else appears to work ok
Make sure you have the MagLite bulb with the flange, it is integral to the operation of the light.
Sep 06, 2011 | MagLite Mag-Lite& Flashlight
How do I remove Flashpoint from my computer system?
What is Flashpoint? If it's a software program, and you cannot uninstall it through Windows, then try using Glary Utilities. It's free to use (not shareware). Google it but you'll find it on cnet (downloads.com). It can remove software programs better than what Windows can do. Also can clean your registry and many other things. It works great (I use it in my Windows XP home edition SP3 computer).
Dec 04, 2010 | IBM Computers & Internet
I can't remember how to put my 'barn' doors on my flashpoint light..
You did not mention the model of your camera to make the viewers answer it easily. As a photography enthusiast you should not be forgetful of all the details of your camera or try to look for its manual instead.
Feb 15, 2010 | Flashpoint Bright Beam 300 Watt Continuous...
I just bought the Flashpoint Bright Beam 300 watt continuous output and it came with a 300 watt DRA bulb. The bulb is really tiny and it doesn't seem to fit directly into the actual light. Is there another...
no, i have the same light...i just inserted the 2 pronged lightbulb in the middle of the metal plate where there should be a small socket with 2 holes...you have to be carefull with these kinda bulbs...they are easily damaged, prongs being broke from being put in and out...too frequently and ect.
Feb 02, 2010 | Flashpoint Bright Beam 300 Watt Continuous...
I'm trying to replace the 3047 with 3043 but have software with 3047 code imbedded in an app. that I don't have control of.
You need the right software for the correct driver. For example if you can't run a mac software on a ibm machine.
Dec 14, 2009 | Integral FlashBus MV Lite (3047) Video...
Old cards don't fit new computers
Here is the description of the card :
FlashPoint 3Dx Lite is available in either AGP 2x or PCI formats. It has 3 video inputs and 1 I/O and flash sync trigger, and is fully compatible with entire line of FlashPoint 3Dx products....
If its AGP 2x of course it will not work and ametehan is right in asking if its Vista because a lot of manufacturer didn't make the drivers for all of there cards.
May 28, 2009 | Integral FlashPoint 3Dx Plus (3282) Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
