Question about AEG 2.83 cu. ft. / 80 liter Upright Freezer Arctis A75100GA
Throws the trip occasionally - AEG 2.83 cu. ft. / 80 liter Upright Freezer Arctis A75100GA
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Freezer keeps tripping breaker
Possible that it is draining a larger current and so it trips the breaker. Check if the capacitor to the motor is faulty, replace if you find it on test to consume more current and low charge.
Also the motor can be checked , the wiring to the freezer specially the GROUND connection as any leak can also trip the circuit.
Jul 18, 2011 | Silver King 1242.90 Front Breathing...
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
We had a freon leak, I wondering do we need to throw all the food away that was in the freezer??
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
Dec 05, 2010 | GE Freezers
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Tripping the breaker
Check the start relay. If it is OK the compressor is bad.
May 12, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer attempts to start but after a few seconds trips out
There is a relay and protector, these are where the wires attach to the compressor,or rather how the power wires attach to the compressor.You can purchase a 3n1 start kit which has the instructions with it. Be sure to unplug the freezer before touching the wires or attempting to install replacement parts.
Mar 08, 2009 | Freezers
MAIN RCD CIRCUIT TRIPPING OUT
it may not be the freezer. ground fault recept. are known to go bad pretty regular. upplug freezer and see if it still trips. It doesn't take much to trip one, so look for something simple
Aug 18, 2008 | Freezers
AEG 2.83 cu. ft. / 80 liter Upright Freezer Arctis A75100GA Logo
60 people viewed this question
Top AEG Freezers Experts
Gil Shultz
Victor Nwachukwu
Victor Nwachukwu
AJMAL KHAN
Are you an AEG Freezer Expert? Answer questions, earn points and help others
