Question about GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven
Out-of-the-box new ge microwave light on/doesn't work at all
Opened box of new GE Microwave, took it out, plugged it in, inside light on constantly but doesn't turn on/work at all?
MicrowaveSvc
  • 9047 Answers
SOURCE: Light Stays ON Inside - JE2160
If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
If not, then I would suspect a bad door switch or a problem on the control board.
We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
  • 2692 Answers
SOURCE: Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Posted on Dec 31, 2008
MNfisherman
  • 11896 Answers
SOURCE: GE Spacemaker Microwave lights flicker on then off
There must be a short in the wiring between the bulb sockets and the power supply or control board. Otherwise the short may be in the bulb sockets themselves.
I would test the connections to make sure the wires aren't loose and all solder joints are tight. If all wires look good, and bulb sockets are tight, then the problem may be faulty capacitor
Posted on Jul 09, 2009
jtd866
  • 71 Answers
SOURCE: GE microwave will not heat, everything else works, any ideas?
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Posted on Sep 16, 2009
rynanlimpiad
  • 36 Answers
SOURCE: change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Posted on Apr 21, 2010
Need to paint the inside of my 2001/240 v. Ge advanium what do you recommed
I wouldn't recommend painting it. The inside of the microwave is a box that allows microwaves to bounce around off those walls. If you paint the inside of your box you could have a serious fire hazard. I would send and e-mail to GE and see if they recommend anything that is microwave safe.
Mar 26, 2015 | GE Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
I have a GE jvm1790 microwave that when its pluged in, the magnatron fan runs with the interior light is on constantly. I can't start either the microwave or convection. Everything stops when the door is...
The megatron tube is not working. The microwave should turn off when the door is opened for safety. If it is still under warranty, return it. If not, you may consider replacing the unit. I know its expensive, but its just taking up cabinet space tonight.
Nov 06, 2009 | GE JVM1790SK Convection/Microwave Oven
Inside Light stays on and the Start Button will not work at all!
You probably broke the door sensor switch.
The part must be tested before replacement.
Parts can be purchased from Partselect, Appliancespartspro, or Repairclinic. Have a look on google.
May 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
Please write back with more details if you need further help.
Nov 30, 2007 | GE JE2160 Microwave Oven
Microwave jvm1860
I had a repair man out to fix my microwave and all it took was to reset the unit. We shut off the power source ( at the breaker box ) and turned it back on. This had the effect of a reset. Now it works fine. Hope this helps.
Jan 09, 2007 | GE JES1851 Microwave Oven
GE Used JES1453SR1SS 1.4 cu. ft. 1600 Watt Countertop Microwave Oven Logo
16 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
