Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
How to change fuse in maytag #MFI2569VEB2 - Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
My Maytag Neptune MAH5500B wont start.We thought it was the control board so we change it.And still wont start
Have you checked the thermal fuses? The main cause of dryers not starting is the thermal fuse.
Mar 06, 2015 | Maytag Neptune MAH5500B Front Load Washer
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Changing dryer belt
pop up the lid and you will notice a short heat element with blue thermastat, you will also notice 2 white wires that goes down to a fuse, that fuse is blown out, it is round on the side of the element housing. you need to get a Maytag fuse kit which will come in the package as a thermastat blue in color and 2 fuses, you will only use one of the fuses, one is for a gas and one is for electric, pink dot for electric, yellow dot for gas.
Sep 15, 2009 | Dryers
Where is the thermal fuse located on maytag intellidry sde505dayw? the dryer tumbles but doesn't dry. no lint or ventilation problems.
right with the heating element, first check for 220 volts at the element if you dont get 220 change the fuse if you do get it change the element... i can send you both parts if you visit whirlpoolpartssurplus.com and call me- mark
Jun 26, 2009 | Maytag PYE2300AY Electric Dryer
My dryer quit working and I think it is the thermal fuse.
maytag neptune?..remove door and screws on other side too.. pop off front. :)
Jun 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to change the fuse in a maytag neptune dryer
it could be a thermal fuse, or it could be your element. the only way to know for sure ( without just replacing parts ) is to test them with an ohm meter on tone.
to get to these parts, you need to open the door and remove the 4 screws ( 2 on either side ). then you can remove the front panel. you now have access to the element and the thermal fuse which is on the element canister.
if you get tone, then the part is good. Joe
Oct 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
