Question about Gaggenau Kitchen Appliances - Others
What happens when you start it with no oil? - Gaggenau Kitchen Appliances - Others
Oil Pressure Loss
By the sound of it you are still driving the vehicle and it hasnt destroyed itself so I would guess that the oil pressure sensor is failing.
Jan 20, 2016 | 1985 Chevrolet S-10 Blazer
Engine clatter
Have a mechanic or shop put a mechanical oil pressure gauge in the oil pressure sending unit's mounting hole. Check oil pressure against the spec for your car. Does the warning light turn on every time this happens? If so, try to check oil pressure when the light is on-you may have an intermittent oil pressure problem, or oil pressure may just be too low. Don't believe it's a sensor, don't know how, but not familiar with your newer ride. Something as simple as a pick up tube gasket that leaks could cause low oil pressure. If that happens, the top end of engine will clatter-not getting enough oil up there.
Dec 21, 2013 | 2009 Chevrolet Traverse
My car started to stall while driving. My oil change was due so I panicked-thought engine was seizing. Added oil- all was good. This has happened twice in 10 days-now it happened again today. Car is a...
Di you check your oil? or just add some..Did you get your oil changed and it happened again?..not really a solution yet, but more info. is needed.
Oct 14, 2013 | Cars & Trucks
Generator spewing oil
if too much oil it will do this , the oil is pushed past the piston rings , fill to correct level , if it does it with correct oil level the piston rings are gone,
Feb 29, 2012 | Hammering
1973 FLH 1200. has approx 23,000 original miles, h...
What happened to your bike was all the oil that came out was in the engine crankcase and the scavenger pump scavenged it all out OK, that's where it goes out through the breather. How that happens is the oil after time seeps past the check ball that is supposed to keeps oil in the upper end somewhat to avoid drystarts etc.
Check your oil level now, add what you need, and ride.
May 20, 2010 | Motorcycles
Started mower and mowed a short distance...lost power and oil started coming out of the motor. Is motor ruined or is rings stuck?
This is what happens when the oil is overfilled. If that is what happened, you may be able to clean it up and correct the oil level. It may run smoky for a while, and you may have to replace the plug.
Apr 05, 2010 | Craftsman Garden
Major oil leak after putting in new starter
Take off your oil filter and replace it immediately. What happened was your oil seal fell off your oil filter when you took it off.
Good luck
Aug 07, 2009 | 1998 Nissan Pathfinder
Ford F150 oil gauge
Sounds like you need an oil-pressure sending unit.
May 07, 2009 | Ford F-150 Cars & Trucks
Oil pressure sometime goes too low causeing the oil light to come
Of course you realize that the pressure fluctuates according to your acceleration right? If it's going lower than it normally did than there can be a compression problem with the engine or possibly the oil pump is putting out a low output.
Mar 12, 2009 | 1993 Jaguar XJ6
Kitchen Appliances - Others Logo
23 people viewed this question
Top Gaggenau Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Gaggenau Kitchen Appliances - Other Expert? Answer questions, earn points and help others
