Convergence problem with samsung sp42w5hfx
Hi i have a samsung sp42w5hfx rear projection, i have changed both ic's and one pico fuse, in service menu i can only move green red and blue will not converge.....can anyone help me on this matter...any thanks
  • 1 more comment
  • gb12345 Mar 15, 2008
    I have same problem any clue.
  • shaun dolphin Jun 03, 2008
    I have same prob too is this a common fault ? Changed both convergence chips STK392-040 - Now only green and red will move - Blue will move up and down but not left and right also one of the STK's is getting very hot any ideas ??? shaundolphin@yahoo.co.uk
  • Sarah29 May 11, 2010
  • 20 Answers
Posted on Jun 03, 2008
  • 372 Answers
Hi.
Post your email address & I will send convergence set up manual.
http://dysonmanuals.inc.io/
Chris..
Posted on Nov 04, 2007
  • chris pursloe
    chris pursloe Jun 04, 2008
    Hi.
    Very strange problem your all having.
    The guy who says one ic is getting hot this is mormall im concerned about the cold ic.
    Ok all of you who cant move the blue try swapping the ics over and see if blue now moves properly but the red doesnt if this is the case then there is either a problem with one of the new ics or a problem with the circuit.
    As I said I have never had this problem after replacing the ICs but will try & see what I can find out.
    http://dysonmanuals.llc.nu/
I have a Samsung Rear Projection TV with an HDTV 1080i Monitor. I know the convergence is messed up because the blue would not move when I tried to adjust it on the menu. So, then I tried to make it
You will need to replace both convergence Ics and the pico fuses that blow when the Ics fail. You can get the replacement Ics and pico fuses from www.tvreairworld.com they also provide free tech support to help you install them
Oct 27, 2012 | Samsung HC-P4752W 47" Rear Projection...
Convergance color off set on screen
very common problem the 2 convergence ICs and the pico fuses will need to be changed. The Sony type 1 convergence repair kit from www.tvrepairworld.com is the correct kit for your model and contains the two ICs and the 8 pico fuses plus the CD with repair instructions.
Oct 04, 2011 | Sony KP-46WT500 46" Rear Projection...
Cant adjust the convergence in menu colors look ghost,3d looking
You will need to replace the two convergence ICs and then check and possibly replace the pico fuses on the D board and G board. The Sony number one convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains both ICs and the 8 pico fuses plus the CD with detailed repair instructions.
Sep 22, 2011 | Sony KP-51WS510 51" Rear Projection...
My t.v is having a convergence problem, and when using menu button from the remote control. there is no convergence option. Would adjusting the Lens from inside the t.v, give the same possible solution as...
Replace Both of your convergence ICs they are mounted on front bottom bord to left hand side will have STK on them STK392-150s Also CK pico fuses in front of ics they look like resistors but will be yellow or green pico fuses 5amps/6amps Call Mats for ICs 1-800-628-1118 And you Have to know How to Enter Service Menu for alinement to Convergence. PRESS( display/ ch /5 / vol- do this in order then you shold be in the service menu!
Jan 02, 2010 | Sony KP-43HT20 43" Rear Projection...
KP-51WS510 convergence problem. Replaced IC's and pico fuse
Nothing else to look for but to Replace the Convergence Ic's
Nov 06, 2009 | Sony KP-51WS510 51" Rear Projection...
Convergence problem philips rear projection tv.
All convergence circuits require two voltages which are equal, one being positive the other negative. Check the power supply for these two voltages and then see if you're getting them at the output ICs. I suspect one of them is missing or low. If there are no cooked resistors near the ICs, inspect the fuses that protect those two voltage sources or the regulating devices themselves.
michtech
Feb 16, 2009 | Philips 50PP9202 50" Rear Projection...
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Samsung pcl5415rb convergence problems
If you bought a kit from sites such as TvRepairKits.com go back and ask for help. If you bought the parts over the internet without instructions you have two common problems...1) Bad/Fake chips... or 2) You did the repair wrong - because you lack proper instrucitons.
Pico fuses - yes - they can be one of many secondary reasons convergence is not fixed on Samsung models.
Nov 13, 2008 | Samsung PCL5415RB 54" Rear Projection...
Sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung rear projection sp42w5hfx convergence problem
Compare IC connections with meter = check solder joints to
see if some are touching one another. Tell me exactly what
brand & part number was installed...........T.
PS. The red,green,blue plugs may be mixed up because the green should stay and red & blue move !
Nov 03, 2007 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
556 people viewed this question
Top Televison & Video Experts
