Question about Logitech USB Illuminated Laptop Keyboard-820-001268
Blank space between letters appears intermittently
Intermittent blank on asus a43sa vxo22d
The problem may be in the video cord from the screen to the motherboard, sometimes the plugin works it's way loose from the main board, if the lid is extended back that is where the intermittent symptoms tend to appear.
May 14, 2012 | Computers & Internet
Tip
Blackberry Tips
<br /> <img src="gfxcasa_0.jpg" /> <br /> <ul> <li>To move the cursor in a different direction, hold down the<i> Alt key</i> and roll the trackwheel.</li> <li>For a letter, hold the letter key until the capitalized letter appears.</li> <li>To go to a screen, press the Space key. To move a screen, press <i>Shift + Space key</i>.</li> <li>To move to the next item, press N. To go to the previous item, <i>press P</i>.</li> <li>In the<i> calendar</i>, to change the calendar view, press A. To switch to day mode, <i>press D</i>. To change to Week view, press W. To change to Month view, <i>press M</i>.</li> <li>Making use of the letter, hold the letter key until the capitalized letter appears.</li></ul>
on Dec 06, 2010 | Cell Phones
I have a freeagent go 500gb portable hard drive. Is it possible to divide it into two 250gb partitions?how?
yes it is possible. First you can use a partition software. The second is using the disk management tools, these are the steps.
1.To run Disk Management Tool, click on Start, right-click My Computer, and select Manage from the menu that appears. When you see the Computer Management window, click the Disk Management item listed underneath the Storage heading. You then see the main Disk Management pane in the right side of the Computer Management window.
2.Creating the partition: Unallocated space appears as an Unknown Partition in the Disk Management diagram, you can use it to create a new partition in some or all of the space. To create your new partition, you need to right-click on the part of the diagram that represents the unallocated space, the unallocated space has a black stripe running along the top and then choose the "New Partition" on the menu that appears. To create your new logical drive in an extended partition that has free space The free space has a light green strip along the top, right-click on the free space then choose New Logical Drive from the menu that appears. Now you will see the New Partition Wizard.
The Partition Wizard will asks you to specify the following:
1 The Type - Primary, extended, or logical partition. Your hard drive can contain up to four primary partitions, or three primary partitions and one extended partition. Choose the primary partition if you are created a partition in which you will install an operating system (this is unusual situation). Choose extended if you plan to create several logical partitions within it. The logical partition type is available only if you choose to create the new partition in an extended partition with some free space.
2 The Size - You may use the entire available space, or leave room for more partitions. The Partition Wizard will displays the minimum and maximum size for the partition, this is based on the space where it will be stored
3 The Drive letter or path - Two operating system on your computer. You may select any unused letter, but the wizard will offer the next available drive letter. To Mount in the following empty NTFS Folder, you need an NTFS partition with a drive letter on the same machine. You may select the "Do Not Assign A Drive Letter Or Drive Path" option, this will let Windows assign a letter later, usually the default drive letter.
4 The File system - The default is NTFS (recommended), but you can use FAT32 (not recommended) as well. Both NTFS and FAT32 will efficiently utilize disk space on large drives.
Note: NTFS has better security features, the better recovery capabilities after a major crash, and has file-level compression built in. NTFS will also give you the option of enable compression.
5 The Label - Type a name for the partition, name it something that will indicating what you will use it for, data files, my files, fatboy one, etc.
I hope this solution was helpful.
Aug 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How can i select auto pause on my player model je510 thanks
Inserting blank spaces while recording to tape (Auto Space)
The Auto Space Function inserts a 3-second blank space between each track while recording from MDs to tapes, allowing you to use the AMS function during later playback.
Press A.SPACE repeatedly until “A.SPACE” appears in
the display.
To cancel Auto Space
Press A.SPACE repeatedly until “A.SPACE” disappears.
Note
If the Auto Space Function is on while recording a selection containing multiple track numbers, (for example, a medley or symphony), blank spaces will be inserted within the selection whenever the track number changes.
See Page 21 of your User Manual
May 23, 2010 | Sony MDS-JE480 Mini Disc Player
SCreen goes blank intermittendtly
It is OK that there is enough space where your PS3 is located but what is required is ventilation to take out the heat which may be the case in this case. Therefore try to put PS3 in a place where the place gets enough ventilation. There is no other reason for screen going blank intermittently Also, it is suggested that you clean the terminals of the cables periodically by disconnecting them as the heat attracts dust and the contacts become dirty with dust thus affecting the connections
Apr 12, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Hp Laserjet5: intermittent blank spaces, random
check the toner cartridge.. all the image formation occurs inside the toner ctg.. if you have quality issues try another ctg! Smiles
Mar 31, 2010 | HP Office Equipment & Supplies
Keys don't match letters
On the L. side of the keyboard is the pitch selector switch it may be in PS proportional space it should be in 10. 12 or 15 also dlide it up & down a few times they do get dirty.
DickyO
Jan 05, 2010 | Nakajima AE-710 Typewriter
Changing the first letter of a proper name from small cap to large cap? I have a Uniden Dect 6.0.
When entering a name in the phone book, after a blank space the first letter is always a capital one. Subsequent ones are small letters.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Jun 26, 2009 | Royal Office Equipment & Supplies
How do I space things out when doing addresses
If you are asking how to space things such as state names, etc., there is a blank key on the keypad when you are entering addresses. This is the space key and will put a space between letters. If there is something else you are trying to do, please let me know.
Mar 03, 2008 | GPS
Logitech USB Illuminated Laptop Keyboard-820-001268 Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
