Question about Xerox Office Equipment & Supplies
Phaser 6180 MEP, error 116-324 - Xerox Office Equipment & Supplies
  • 2072 Answers
SOURCE: XEROX PHASER 6180 LASER ERROR
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
Posted on Sep 04, 2008
SOURCE: phaser 6180 error code 033-762 Fax not recieving
possibly junk fax feature is ON which assumes every fax you receive should have sender fax numer pre-registered, otherwise it just rejects the fax sent from an un-registered number
Posted on Jan 31, 2011
  • 395 Answers
SOURCE: I have a Xerox Phaser
Here is the solution I found to match exact your model and error codes
Error code 093-951 is related to print cartridge crum error magenta
Solutions include:
If the printer is connected to a network, check the Print Cartridge level using CentreWare Internet Services (CWIS) and replace the cartridge, if necessary. See the Related Items below for additional information.
If the printer is connected to a computer via USB, replace the Print Cartridge, if necessary. See theRelated Items below.
To check the Print Cartridge levels using CWIS:
NOTE: If necessary, print a Configuration Report to obtain the IP address of the printer. See theRelated Items below.
  1. Open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Status] button. The Status window will be displayed.
  4. Click on the [Supplies] link. The cartridge levels will be displayed in the Toner Cartridgessection.
  5. If necessary, replace the Print Cartridge (you mentioned you removed the toner only, so check the level of toner to see if you need to replace it)
  6. When finished, close the browser window.
And
  • Power off the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  • Wait at least 10 seconds.
  • Power on the machine. Press the power switch to the (') position.
  • Error 52 means Remove the Duplex Unit (if installed), check for paper under the upper tray, and turn power off then On.
  • Hope this helps
  • Thanks
  • Posted on May 05, 2011
    StevenC82
    • 160 Answers
    SOURCE: my phaser 6180 transfer life repalce soon what is
    If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
    For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
    Posted on Dec 19, 2011
    • 217 Answers
    SOURCE: Xerox Phaser 6180 keeps saying load papertray with
    There can be another case of this message.
    If the paper isn't being 'lifted' due to a fault, or just wear, in the paper tray.
    Pull out the paper tray (as if you were loading it, push the paper tray back in. Now open the front door of the printer and look inside at the bottom of the printer. Has the paper lifted, so that it is in contact with the pickup/feed rollers.
    If it hasn't, a replacement paper tray will probably sort it out.
    Posted on Sep 24, 2015
    Xerox phaser 6180 has error code LPR and blue horizontal marks in background show up.
    Background is usually a cleaner unit fault, need to check out more on this point. Best to start from this point and try this to see if you can make changes.
    Good luck.
    Oct 06, 2014 | Xerox Office Equipment & Supplies
    Need Error codes for a Xerox Phaser 6180
    Anonymous,
    What exactly are you asking for here?
    Best regards,
    Jun 20, 2014 | Xerox Phaser 6180N Laser Printer
    Xerox Phaser 6280 Y CRUM ERROR
    The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
    Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
    Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
    ERROR 093-951
    http://www.refillbros.com/en/manuals/p1643-xerox-phaser-6280-service-manual?page=199
    see this page for detail and how to repair
    i hope this helpfull, if you think this helpfull please rate very helpfull
    thanks for using fixya
    Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
    My phaser 6180 transfer life repalce soon what is
    Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
    Phaser 6180 error code 033-762 Fax not recieving
    Jan 05, 2010 | Xerox Phaser 6180N Laser Printer
    I have a Xerox Phaser 6180. I have not had any
    You more than likely need to place a service call.
    Over temp can be related to the fuser control circuits,
    Don
    Dec 15, 2009 | Xerox Phaser 6180N Laser Printer
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
