Question about Sub-Zero 642
How do you replace ice maker filter in a sub zero refrigerator 642
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
  • 56 Answers
SOURCE: Ice maker in Sub Zero 642
Call the factory at 800-222-7820 for the manual. It souns like you are missing one or two screws. Pull the ice tray out and lift it up about an inch and it should release. Take a look at the ice maker and there are two supports that both need to have screws on them. There is also a third underneath on some models. Insert the screws and you should be fine.
Posted on Dec 02, 2008
hbsurfdawg
  • 95 Answers
SOURCE: Ice Maker won't work
If your trying to save a service call you have your work cut out for you. The ice maker is a unit that sits by itself attached to the wall or part of the freezer wall.
There are many reasons why you do not get ice and I will list them.
1- Temp of freezer got too cold and has frozen the pipe that feeds the water to fill the icemaker.
check to see if the icemaker has any ice in the area that fills and makes the cubes.
If the pipe is clogged, very gently put a small tipped screw driver in the fill hose that sites over the ice making row in the ice maker. Be careful you do not push your screwdriver out the back of the refer.
Check to see the freezer temp is not too cold and is freezing that pipe. 0-3 degrees F is good.
2.- check to make sure your water feeding the fridge is on. There is an on off valve to allow the water to feed the icemaker when it needs to fill. This could be bad. there are reset proceedures for the fridge, but unplugging the entire frige for 1 minute and plugging it back in you can listen for the the valve to come on and see if it fills the ice maker resevoir.
3. If it fills and freezes the ice resevoir, then the sensor in the ice tray does not sense the frozen ice and will not cycle and kick cubes. At this point, unless you are super tech, you will need to replace the entire icemaker unit.
Hope this helps.
Posted on Mar 21, 2009
  • 5 Answers
SOURCE: Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Posted on Jul 30, 2009
I have sub zero 642 and my techinician says that I need a ice make valve replacement. He says it costs $495, does that seem accurate?
Sub-Zero a hallowed name in refrigeration, and the 642 side-by-side refrigerator/freezer unit is a landmark Yeah, it's that impressive. Dual refrigeration uses two compressors and three evaporators, I can tell you to never expect less than $300 for calling anyone to your home!
Aug 10, 2011 | Sub-Zero 642
I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
Here is a link to a Sub Zero Repair Video
http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
Feb 20, 2011 | Sub-Zero Refrigerators
Ice maker is not working. I cleaned out ice and put back but now it won't make ice .
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
poyoiyu
Oct 07, 2009 | Sub-Zero 642
Subzero 642 Ice maker issue
Called repair service that seller recommends.
Aug 22, 2009 | Sub-Zero 642
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Sub-Zero 642 ice maker
When the drawer is opened, trhe "full arm" swings up and out of the way. When the drawer is pushed back closed, the arm should swing back down. If it is unobstructed, the icemaker should make ice.
One thing to try is with the ice tray removed, push the plate (that holds the ice tray) back into the freezer. Lift the full arm up and down. It should easily move and you should be able to hear a slight "click" when moving up/down. If not, you might have a bad switch in the ice maker unit...replacement time.
Mar 25, 2009 | Sub-Zero 642
Feb 19, 2009 | Sub-Zero 642
Sep 16, 2008 | Sub-Zero 642
Refrigerators Logo
109 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
