Question about Intertherm Heating & Cooling
1992 NORDYNE/INTERTHERM FEHA-015HA-01 DOES THIS UNIT HAVE FUSES
BLOWER WON'TKICK ON MOTOR IS GOOD NEW CAPACITOR AND THERMASTAT DOES THIS UNIT HAVE FUSES?
    Sergeant:
    Champion:
  • 234 Answers
It should have a 3 or 5 amp fuse on the circuit board.
Posted on Nov 26, 2014
3 Suggested Answers
  • 25 Answers
SOURCE: WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
Posted on Oct 09, 2009
  • 415 Answers
SOURCE: Thermostat wiring diagram for Intertherm FEHA-015HA-01
Installation Manual
Posted on May 19, 2010
Testimonial: "EXCELLENT EXACTLY WHAT I NEEDED!!!! THANKS!!!!"
Why is my Intertherm nordyne ac unit fan not coming on?
It could be a bad wire or broken,burned etc. Or the capacitor is bad. The motor may have seized up.
Apr 29, 2014 | Intertherm Heating & Cooling
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
HEATER MODEL FEHA-015HA-01 SN FEH9302-03330 BLOWER WON'T KICK ON IN HEATER. MOST OF THE TIME, TAPPING ON RACEWAY PANEL OR RELAY BOX COVER WILL MAKE IT COME ON. DO YOU KNOW WHAT THE PROBLEM COULD BE?
Sounds like a bad fan relay or sequencer. From your model number it looks like a 15 kw heat. Some unit the first stage heat brings on the fan. So I would replace sequencer and that should solve your problem. Easy to change. Just replace wire per wire. Rus
Dec 07, 2009 | Refrigerators
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Apr 11, 2009 | Heating & Cooling
Need a schematic for nordyne intertherm model e1eb-015ha
Nordyne no longer has the E1 model in there literature not even in their archieved documents but I have included a link to for the E2 model which will be very similar to yours. These units are very simple and all only vary slightly. It should give you enough info to get you through what you want to know.
http://www.nordyne.com/literature/7103180.pdf
Apr 04, 2009 | Heating & Cooling
No heat fan running
This is a 10 Seer electric heat package unit. There are few possibilities. Does the blower come on when you put the t-stat on Fan on? If it does, then it is probably the blower time delay relay which is nordyne part# 622181. If the blower doesn't come on at all, check that the blower is getting power and if it is, then the blower motor is bad but could possibly be the capacitor as well. Both should be checked.
Mar 31, 2009 | Intertherm P3RA-036K Air Conditioner
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
112 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
