Honeywell cm921 heating should be on but no flame symbol on display.please help
SOURCE: HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Posted on Oct 27, 2008
  • 55 Answers
SOURCE: Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
Posted on Sep 13, 2009
SOURCE: heat pump works in emergency heat, but not in auxiliary heat
I set the thermostat for 70 degrees. It comes on always in auxillary heat and does not shut off when it reaches 70 degrees. It is a heat pump, I am assuming, it might be the thermostat? But when the air conditioner is on, it turns off when it reaches it's temperature.
Posted on Oct 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Honeywell Thermostat CM67NG The flame
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Posted on Nov 30, 2009
SOURCE: Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
honeywell cm921 problem with red light flashing tenp not controling boiler can any one hel
Posted on Dec 15, 2009
My Honeywell dt200 is displaying a flame when I turn it on but isn't actually heating.
The problem could be with the heating unit or furnace and not the thermostat.
Aug 10, 2015 | Honeywell Programmable Thermostat Heater
CM921 LCD figures breaking up
Hi There - I have a similar problem to the one described by yourself . Did anyone offer any help or assistance on this at all ?
Many thanks
M Hudson
Jul 15, 2013 | Honeywell Programmable Thermostat Heater
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell Thermostat CM67NG The flame symbol is showing on the thermostat, but there is no heat from radiators. The status code on boiler says there is ' no heat demand'. Boiler shows radiator...
Nov 30, 2009 | Honeywell Programmable Thermostat Heater
Sep 02, 2009 | Honeywell Programmable Thermostat Heater
Cm921 does not seem to switch back on quick enough
sounds like you might have to move dipswitch to control cycles per hour found on back of t stat set for system type
Feb 02, 2009 | Honeywell Programmable Thermostat Heater
I have an icon similar to a fire flame showing on my honeywell Energy star thermastat for my home central ac and heating unit. what does this mean because my heat has stopped working
hi this is mr.grzz, well to answer your question, the little icon on your t-stat that shows a little flame means that your t-stat is calling for heat, there in lies the problem your t-stat is doing what it is supossed to do, your problem lies with the furnace, it could be a nuber of things wrong, but first and formost, try turning the power off to the furnace at the breaker panel, wait for about 30 seconds, then turn the power back on, this resets the circuit board, see if that will help your furnace to run, but there is a reason behind why your furnace failed, if this does the trick, then great, if not please fell free to come back and let us know what the furnace is doing after it trys to start up, thanks for your question, hope that helps, mr.grzz
Jan 20, 2009 | Heating & Cooling
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
