Question about Stryker Fiber Optic Light Cable 233-050-064 10
Can it be autoclaved? - Stryker Fiber Optic Light Cable 233-050-064 10
Find a replacement power cord for my autoclave
Yes same for me trying to get a replacment cord can't find any info on them
Jan 12, 2015 | Science & Laboratory
I need the manual of mammouth autoclave
Further info needed. Do you have a Model and serial number?
May 27, 2014 | Science & Laboratory
Power failure
Might be several things. First though, verify that your power outlet can provide enough power that is specified to operate.
Mar 26, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Turned off autoclave in the middle of a cicle
What exactly is wrong that you need help with? More info needed. Why was it turned off? Did it turn off by itself?
Feb 19, 2014 | Science & Laboratory
Short beeping with no error code
...no informative error? bacteriological filter? time for maintenance?
Jan 09, 2014 | Joyfay 12L Vacuum Steam Autoclave Medical...
7 whenI have autoclave Euronda E switch on , an error say no power supply ... any solution please ?
http://www.euronda.com/contacts.aspx
See if voltage is available to the unit. If so,. Replace the power supply within the unit itself.
Dec 08, 2013 | Science & Laboratory
What are autoclaves used for?
Autoclaves are used to sterilize equipment like those used in surgery or in a microbiology lab. They are also sometimes seen in tattoo parlors for sterilizing the needles.
Oct 20, 2013 | Science & Laboratory
Sun series autoclave
The connect wire might be broken or the print.....
Jul 17, 2013 | Science & Laboratory
What are some different ways to remove air from the autoclave?
downward displacement, steam pulsing, vacuum pumps, superatmospheric cycles, subatmospheric cycles. http://en.wikipedia.org/wiki/Autoclave
Apr 29, 2013 | Science & Laboratory
Stryker Fiber Optic Light Cable 233-050-064 10 Logo
29 people viewed this question
Top Stryker Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Stryker Science and Laboratory Expert? Answer questions, earn points and help others
