Question about Ryobi 753-04344 Upper Drive Shaft and Housing Assembly Shaft is 25-1/8"
How to remove grip 791-180866 from shaft 791-181969 for use on replacement shaft 753-04344?
Can the core of a new shaft be removed to swap with the core of the old shaft?
Craftsman dual action sander model#875.199770. how do you remove sanding pad to replace with new one?
I used a thin vise grip to hold the spindle and the old rubber pad was easily removed.
Apr 17, 2013 | Craftsman Dual Action Sander
How do i replace heater core in 1990 cutlass calais s 4 cyl 2.5L
Hi Ronald,
That vehicle is equipped with one of the easiest heater cores in the world to replace. Here are the instructions form the service manual:
Drain cooling system. Raise vehicle. From underneath, remove heater hoses from heater core. Remove drain tube. Lower vehicle. Remove right and left side sound insulator panels. Lower heating duct and hoses. Remove heater core cover and heater core. To install, reverse procedure. Fill and bleed cooling system.
HINT: I never drain the cooling system to replace a heater core. It is not necessary if you use a couple pairs of long-nose Vise-Grips to clamp off the heater hoses before you disconnect them from the heater core. That way, the only coolant you will lose is what is actually in the heater core itself.
Nov 25, 2011 | 1990 Oldsmobile Cutlass Calais
Replacing heater core chryler picifica
  1. Remove the silencer boot fasteners located around the base of the lower steering shaft from the dash panel so that it may be pushed aside.
  2. Remove the brake lamp switch from its mounting bracket.
  3. Disconnect the power brake booster input rod (push rod) from the pin on the brake pedal arm.
  4. If equipped with power adjustable pedals, remove the adjustable pedal assembly.
Note: Take the proper precautions to protect the carpeting below the heater core from spilled engine coolant and have absorbent toweling readily available to clean up any spills.
  1. Remove the heater core tubes.
  2. Remove the two screws that secure the heater core mounting plate to the HVAC air distribution
    1. If NOT equipped with power adjustable pedals, pull the accelerator pedal upward and push the brake pedal downward for clearance to remove the heater core from the air distribution housing.
    2. Remove the heater core by carefully pulling it straight out of the side of the air distribution housing.
    Installation
    1. If NOT equipped with power adjustable pedals, pull the accelerator pedal upward and push the brake pedal downward for clearance to install the heater core into the HVAC air distribution housing.
    2. Install the heater core by carefully pushing it straight into the side of the air distribution housing.
    3. Install the two screws that secure the heater core to the air distribution housing. Tighten the screws to 2 Nm ( 17 in lbs ) .
    4. Install the heater core tubes.
    5. If equipped with power adjustable pedals, install the adjustable pedal assembly.
    6. Connect the power brake booster input rod to the pin on the brake pedal arm.
    7. Install a new brake lamp switch.
    8. Install the silencer boot around the base of the lower steering shaft on the dash panel.
    9. Reconnect the negative battery cable.
    10. If the heater core is being replaced, flush the cooling system.
    11. Refill the engine cooling system.
    housing.
Oct 18, 2011 | 2004 Chrysler Pacifica
How to remove the rear licnese plate screws stuck in the holes
drill the screw head off or grind it off, remove the plate, use a pair of pliers to hold the plastic base and a pair of vice grips to grip the shaft of the screw and turn it until it unwinds, remove the plastic base and replace with new ones
hope it works for you as it did for me
Jun 14, 2010 | 2000 Hyundai Accent
How to change the fan blade that is used for the suction on the vacuum cleaner?
You will need to get a genuine fan kit form a service center, then elevate the vac and remove the carpet head. From the back of the housing there will be a series of screws facing forward into the front housing, several are counter sunk. Removing them will replace the front face of the housing. You should not have to pry.Look for partly hidden screws
The belt shaft is threaded, once removed pay attention to washer and spacer location in front and back of fan.
Grip the old fan by hand and the shaft with a set of vice grips or slid a long nail through the fan shaft hole to unscrew the shaft.
Installation is reverse order with the shaft and screws hand tight... Post back to say how you make out
Oct 10, 2009 | Kirby G4 Bagged Upright Vacuum
I need to replace the ac evaporator on a lincoln continental 2001
you have to remove the instrument panel first.
SECTION 412-03: Air Conditioning 2001 Continental Workshop Manual
REMOVAL AND INSTALLATION Evaporator Core Removal
NOTE: The evaporator core is serviced as a core and housing assembly. The evaporator core, internal doors, seals and door linkage are included with the housing. Transfer the blower motor and wheel assembly, heater core and cover, dash panel seals and vacuum actuators to the new housing.
  1. Remove the rear seat airflow duct (18C420). For additional information, refer to Section 412-01 .
  1. Remove the instrument panel (04320). For additional information, refer to Section 501-12 .
  1. Drain the coolant from the radiator so that the coolant level is below the heater core (18476). For additional information, refer to Section 303-03 .
  1. Recover the refrigerant. For additional information, refer to Section 412-00 .
  1. Loosen the screw and disconnect the electrical connector from the powertrain control module (PCM) (12A650).
  1. Disconnect the heater water hoses (18472) from the heater core.
  1. Disconnect the vacuum supply hose.
  1. Disconnect the condenser to evaporator tube and the evaporator to accumulator tube spring lock couplings from the A/C evaporator core (19860). For additional information, refer to Section 412-00 .
  1. Disconnect the evaporator housing electrical connectors.
  1. Remove the nuts and the washers at the cowl panel.
  1. Remove the screws and the A/C evaporator housing.
  1. Remove the screws and the metal cover.
  1. Remove the screws and the A/C electronic blend door actuator.
  1. Remove the A/C air intake flue damper assist spring (19917).
  1. s1e~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not attempt to bend any part of the A/C damper door shaft (19A580). It is brittle and will break.
    Depress the locking ramp and remove the A/C damper door shaft from the air temperature control door shaft.
  1. s1e~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not attempt to bend any part of the lever. It is brittle and will break.
    Remove the A/C evaporator case outlet door shaft (19B752).
  1. Remove the A/C tube dash panel seal (19B588) and the A/C evaporator drain tube seal (19B739).
May 12, 2009 | 2001 Lincoln Continental
Need instructions on replacing filter head on a haywad de filter ec75a
Remove the nuts and bolts around the head of the filter. The top then seperates from the bottom. if the top of the tank is broke you need to remove the black cover and continue disassembly.
Remove the grip from the handle. Usually a squeeze clip to slide grip off. Slide black cover over handle.
Remove bolt holding handle on to bump shaft, might be addtional drift pin that needs to be removed. Tap out with a drift punch.
Once these are removed the bump shaft will be attached to the top and bottom plates with the main gasket still attached. The filter Head is now free to be replaced.
Apr 24, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Kleenmaid KAW 693W-3050 7KG Washer
open the control panel use pliers on the back of the timer shaft then try to remove the knob
Aug 15, 2008 | Washing Machines
I am trying to remove and replace the motor on a whirlpool dryer. i bought the unit new in 1994. i can't seem to get the motor shaft loose. i am trying to turn the shaft in the clockwise direction and with...
check the end threads of the new motor are the not left hand threaded, if so you are tighhtning turn the oppisite direction
btw you may have to replace the blower if it cracked the blower when the plasitc came off might have to use vise grips to ge it off
Apr 26, 2008 | Dryers
Ryobi 753-04344 Upper Drive Shaft and Housing Assembly Shaft is 25-1/8" Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
