Question about Nintendo DS Lite Console
I have the problem but worse...
My whole top screen of my DS Lite is orange, but whenever I turn the hinges it might stay orange, turn blue or go back to normal for a little.
Also one of my friends said that something on the screen might be getting pinched. How can I fix this?
  • 123and123izb Jun 25, 2009
    The only thing is I lost the Warranty
  • 36 Answers
Bring it back to where u got it and have them identify the problem and fixya :)
Posted on Jun 24, 2009
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
My top screen on the ds i have started to go white a while back. it kept getting worse and now i have to continuosly bending the cover back and forth for it to work for mabey 5 minutes. any ideas so i dont...
This is due to a faulty ribbon cable which runs from the bottom half of the ds to the top half via the hinge. Unfortunately the only way to solve this is to purchase a new top lcd screen :(
Jul 28, 2010 | Nintendo DS Lite Console
The top screen on my ds lite keeps flickering lines. this gets worse the longer it's on for but it does seem to help if i play while on charge or close and re-open the ds. I'm not sure what needs replacing...
It might be worth checking the ribbon cable for the top screen is tight in the socket on the main board, this could explain why the screen gets back to normal when you close the ds then reopen. The ribbon cable for the top screen is in the hinge on the left side of the ds when open, the only way to check this is to take the back of the ds, to do this you will need a small philips screw driver and a tri-wing screw driver which you can get of ebay quite cheap. The worst possible fault is the top screen is faulty and needs to be changed, if you do a search in youtube you will find videos on how to do this, they are good and quite detailed. hope this helps.
Feb 17, 2010 | Nintendo DS Lite Pink Console
Whenever I close my DS without turning it off,it doesn't go to sleep, the screen flickers and the sound gets all choppy. when I reopen it,it's just fine. also, the part that holds the top screen up is...
The problem will stem from the cracked right hand hinge and the ribbon and wire that connects to the top screen may have some damage that will be causing the other issue's. The console will require a complete new housing or you may be able to pick up a second hand part from console repair shop, they may have a top section spare that will save on a full housing repair. That will solve the hinge, but a top screen may be also required!!
Jul 13, 2009 | Nintendo DS Lite Console
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Ds lite green light is on but both screens are black and no sound
For GBA games the green light is meant to stay on. The orange light will stay on as long as its recharging. It will turn off when its fully recharged or when you unplug it
Apr 23, 2009 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Ds not lite
Replace the connector cord between two screens. You can buy new ones from DX Deal extreme! Carefully remove through hinge and attach securely.
Be careful not to break the fine wires connecting. Have to twist the connector cord in the correct way to make it go through hinge without damaging.
Good luck cos it is a fiddly job.
Aug 23, 2007 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
119 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
