Question about Saeco Magic De Luxe Espresso Machine
How do you get ur coffee to come out nice and thick like coffee bars?
I use premium coffee beans in the machine, the same beans used in an Italian coffee shop I go to, I know that their machines are commercial, but mine is not even close. what am I doing wrong?
espressodoc
  • 29 Answers
SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Posted on Jul 27, 2007
  • 4 Answers
SOURCE: machine will not grind beans.
That error message will also appear if the coffee grind is too fine.
Posted on Dec 14, 2007
  • 2039 Answers
SOURCE: Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Posted on Jan 15, 2008
mirran
  • 515 Answers
SOURCE: Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Posted on Jul 22, 2008
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
Want to freeze italian green beans
If they are fresh boil them for 3 minutes then freeze them.
Aug 28, 2017 | Italian Coffee Makers & Espresso Machines
Machine says refill bean but its filled
Hello Penny McEwan,
After two lifetimes in electronics... my highly sophisticated electronic background says ...
Get a clean paper sack.
Unplug you unit... and invert the MACHINE pouring the beans into the sack... While holding the machine in that position fetch it a good smack (one on the north side & another on it's south end).
Set the machine back down... like you mean it (good little bump to loosen any coffee bits)... pour the beans back into the hopper...
Plug the little beauty back in and
you should be ready to brew
Else ... get a clean paper sack... (blah blah... blah)
empty it ... smack it... vacuum it out (try again)
Take it to your repair shop!
As for me... after two life times: I still have all the toys...
all put away... nice & clean on the shelf...
I boil 12 cups in a 3 quart pot...shut off the fire and dump in the fresh ground beans let the froth settle (about 5 to 10 minutes)
and pour my first cups through an old fashion Melitta #6
(un-bleached) filter into a 10 cup Melina pot ...
or Chemex carafe
Better than a FRENCH PRESS... camp-fire style without
DRINKING the grounds...
Adjusting the flavor by varying my dark roast between
ITALIAN & FRENCH... with a half mix of PEETS
(Major Dickason's) whole bean... Yum...!!
Big, bold and just like a great big chewy CABERNET
Sauvignon... (CAN'T SEE THROUGH IT).
Never ever leave it on the heat...!
(use the microwave to reheat... or just try ice coffee).
Filter & all goes into the compost
Costco sized cups, bags & 55 gallon drums (of course)
Hope this helps!
Dec 03, 2016 | Coffee Makers & Espresso Machines
My Coffee machine Delonghi doing expresso without foam today. Before doing good expresso with foam. help please.
Espresso should have crema not foam, foam is air added to coffee, like Starbucks does. Issue lays in the grinder and coffee quality. Recommend using Italian espresso bean like Miscela d Oro
Apr 14, 2014 | DeLonghi Coffee Makers & Espresso Machines
Brand new machine. coffee beans are loaded. when trying to make coffee the machine says the beans are empty. thanks
This machine doesn't like oily beans. Your best bet is to buy freshly roasted beans that are roasted to a FC or FC+. Viena, French and Italian roast beans won't work well. Also any beans that you buy at the grocery store will be quite old (often 3 months past roasting date) and they tend to be very oily on the outside.
If you have a coffee stirring stick or a chopstick, lift the cover of the bean hopper and stir the beans and sort of poke them down in the center - that's where the beans stick and can't drop down into the grinding burrs.
If you use oily beans you will need to stir every time or every other time you make a cup. Fresh roasted beans at a slightly lighter roast will work fine.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Hardly any crema is it my coffee italian bean or can i fix this by adjusting the machine?
Try adjusting the grind finer, if that does not work, try another coffee and if you get the same result then the burrs on the grinder need to be replaced.
Apr 16, 2010 | Saeco Vienna SuperAutomatica Coffee...
The coffe grinder smell burn after usage. Is there a way to clean it.
You should check you manual for directions as to how to take the machine apart to clean it because it needs regular cleaning. Since you have not cleaned it in a while, the beans are probably getting super hot and burning inside the grinder because of friction. Also, this particular machine operates best with a drier (less oily)coffee bean... think Italian expresso beans. These drier beans should work better with this machine.
Mar 04, 2010 | Saeco Easy Espresso Machine
Vev Vigano Carioca Nero Espresso Maker..what kind of grind to use
Use fine grind for espresso, darker roasted bean blend on Italian roast style are better, they are stronger and oily, perfect for expresso machines like this.
One of the best available here is this: Lavazza Qualita Rossa Ground Coffee, great brew on Moka style espresso machines.
Feb 16, 2009 | Vev Vigano Carioca Nero Espresso Maker...
Incanto-classic coffee beans do not flow to grinder
The machine automatically stir the beans since the blade make vibration and doing that shake the bean all around.Make sure the the tank is half full so the weight will help on that.If the container is almost empty the bean will fly around and don`t get in the grinder.Back up the machine to the original factory grinding and try to adjust again the wheel
Jun 07, 2008 | Saeco Incanto Classic Espresso Machine
The coffee is never strong enough
Be sure to use a very fine grind of a true Italian Roast espresso bean, and don't be afraid to tamp or pack the coffee a bit. Also, you don't want to overheat the pot...a low flame (or setting on your electric stove) will work best.
Feb 29, 2008 | Vev Vigano Kontessa Inox 6-Cup Espresso...
DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Feb 07, 2008 | Coffee Makers & Espresso Machines
Saeco Magic De Luxe Espresso Machine Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
