Question about De Dietrich DOC310 Electric Single Oven
Control panel on de dietrich dod788x does not work any solution
The light in the main oven works ,the touch panel is dead ,is the problem computing,or fusing ,and probable solution please
SOURCE: Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Posted on Jun 16, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
barkencoa
  • 3463 Answers
SOURCE: my de dietrich oven is
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Posted on Feb 28, 2011
SOURCE: How to get the heating element out of the large
If you mean the element at the back (not the bottom one), inside the oven undo a screw at the back to reveal the element, then undo one more screw attaching the element. THEN, totally disassemble the oven, removing all the cladding, taking off the top oven and controls, detaching lots of wires to be able to do this, in order to finally gain access to the 2 little nuts securing the element behind the oven. Then if you're not sufficiently dismayed by De Dietrich's design skills, email their customer service to be given the wrong part recommendation at twice the price of an independent supplier. Finally, buy part from independent supplier, spend several hours dismantling and rebuilding oven. Then it will work. But maybe don't ever buy De Dietrich (Brandt) again!
Posted on Mar 09, 2011
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
Unlock control panel
Function switch must be in the "O" position
Press the " /\ " button for a few seconds until it beeps.
Then use the +/- buttons to set time.
Try powering off and switching back on again if that doesn't work.
May vary between models but De Deitrich do free manuals downloads. Just google it
Nov 10, 2014 | De Dietrich Ovens
N Serie: 04-09-01097 Ref DOD 348XXG11 Type E248H1 52106 The above are the details of my De Dietrich oven. My fan has stopped working and I need a new seal for the main oven door and for the...
We don't offer service engineers. Look in yellow pages or ask your oven supplier for a contact. Most Domestic Appliance companies can help you.
Sep 25, 2017 | De Dietrich Ovens
My de dietrich oven is not heating. the light and fan are ok
Feb 28, 2011 | De Dietrich Ovens
How to get the heating element out of the large oven in a De Dietrich DOD348*
Dec 22, 2009 | De Dietrich Ovens
De Dietrich DOC310 Electric Single Oven Logo
37 people viewed this question
Top De Dietrich Ovens Experts
ashburton
richie46
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
