Question about Hayward H400FDN Low NOx Natural Gas Pool or Spa Heater
Same issue same unit. It starts up and goes out.
Same issue same unit. Brand new as well ! It starts up and goes out. The gas line goes 70 feet from the meter and is 1 1/4 galvanized which I switched over from 3/4 inch. Same problem even after the switch over. Can you help ?
    President:
  • Hayward Master
  • 1,378 Answers
I hop you did not bury the galvanized. As for the heater, try searching Haywards dervice locator for a local warranty shop. Most will repsond within 48 hours or so. Messing with the unit too much risks voiding warranty coverage.
http://www.haywardnet.com/locator/
Select service and keep increasing the radius until you find someone who can fix it on Hayward's dime.
Posted on Jun 23, 2009
Frigidaire dehumidifier brand new will not start.
Hello Diane Weber, thank you for your inquiry!
I see that you have recently purchased a Frigidaire dehumidifier and the display is not working properly. When you returned the original appliance did they test it in store to see if it worked? Are you using any type of extension cord or surge protector on the appliance? With this additional information I can better assist you. -Matt
Aug 28, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
My 1996 dodge neon is not getting any fuel to the system. theres gas in the car a brand new fuel pump and filter. what could be wrong?
Thanks for choosing FixYa and welcome to the site. Fuel is pumped out of the tank by the fuel pump. It then goes to the fuel filter. Then, it goes through the gas lines to the injectors and engine. You need to scan your gas lines and make sure they are not damaged or clogged. If the lines are ok, you need to check your injectors. Check your fuel pump fuse/relays and reset button, if equipped. I am guessing the car will not start? Thanks for using FixYa.
Apr 10, 2011 | Dodge Neon Cars & Trucks
Need to replace fuel lines on my Troy Bilt gas hedge trimmer. Where can I get replacement fuel lines... or better yet... what size are the lines and where can I buy a few feet of the lines. Note: I...
Replacement fuel lines should be readily available at your local lawnmower repair shop. Your TroyBilt hedger uses fuel line that is 3/32" (2.4mm) interior dimension, 3/16" (4.8mm) outside dimension, with a 3/64" (1.2mm) wall dimension.
Most manufacturers don't offer replacement line, only fuel tank assemblies. Find your local shop, and try to get the TYGON brand...it is yellow. Tygon lasts the longest. You should be able to buy it by the foot for less than $2 per foot. You will need 2 feet of hose to replace both lines.
Make sure to clean the in-tank filter when replacing hoses.
Good luck.
Oct 20, 2010 | Craftsman 22" Gas Hedge Trimmer
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
Rinnai r94lsi comes on 5 sec. then off
if it's a gas unit you mite have to bleed the gas line in and out.
Jan 04, 2009 | Rinnai Webstone The isolator EXP tankless...
Hayward H400FDN Low NOx Natural Gas Pool or Spa Heater Logo
148 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
