Question about Onkyo TX-SR600 Receiver
How to get my onkyo tx sr600 out of protect mode
How to get my onkyo tx sr 600 av recever out of protect mode so i can use it
4 Suggested Answers
Grubhead
  • 5259 Answers
SOURCE: Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Posted on Mar 30, 2010
Testimonial: "Thanks so much. Great solution."
smarthome2
  • 1114 Answers
SOURCE: I turn my Onkyo TX-SR600 receiver on. After a few
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Apr 11, 2010
SOURCE: How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
Posted on Jan 29, 2011
I have a onkyo tx-nr828 that will not power on
To check protect mode: what kind of protection it belongs to when NG channel is displayed such:
NG:LCRSLSRBLBR
NG__CH:LCRSLSRBLBR
1.Press the Enter button
2.Protect cause are displayed for 5 seconds.
DET.PROTECT:I(overcurrent)
DET.PROTECT:V(dc detected)
If warranty still have,call onkyo to repair.
Search you tube SR600 cap replacement and send an email to me, if you want to repair it by yourself.
Oct 04, 2017 | Onkyo Audio Players & Recorders
How to fix Onkyo TX SR 303 when it says phones engaged but no phones are not plugged in
Hello, I suggest a reset of the receiver. Please see the procedure below. Thank you, Onkyo USA.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1/VCR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Feb 28, 2017 | Onkyo Audio Players & Recorders
Onkyo sr600 memory problem
I had the same problem with my TX-SR601 receiver.
Solution: I changed the capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This capacitor is responsible to keep the settings in the memory. It is directly next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
Mar 04, 2012 | Onkyo TX-SR601 Receiver
It shuts down real fast and it says protect right before it goes out
Check that all speaker cables are in place. No shorts and no loose ends. It can also be an internal short.
Jun 28, 2010 | Onkyo TX-SR600 Receiver
May 07, 2010 | Onkyo TX-SR605 Receiver
Mar 30, 2010 | Onkyo TX-SR600 Receiver
I think the amplifier protection circuitry has been enabled. do you know how to reset it?
Check the audio amplifier IC maybe are damaged and need to be replaced
Jan 18, 2010 | Onkyo TX-SR600 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Subwoofer not working on onkyo tx-sr600
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
HTH
Jan 16, 2009 | Onkyo TX-SR600 Receiver
Onkyo TX-SR600 Receiver Logo
96 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
