Question about iPhone Apps
What is force and motion? - iPhone Apps
What is a force?
An interaction which changes the motion of an object.
In Physics, the four fundamental forces are gravatational, electromagjetic, and stong and weak forces (operating at the subatomic level.
A military force is a military unit.
Aug 01, 2017 | Video Game Consoles & Games
A bike traveling at 20km/h on a flat roadway stop pedaling.Make a diagram showing the forces acting on the coasting bike and rider.using newton's second law ,explain how the bike's motion change
How Wide are the Tires?
How much does the Rider Weigh
Is there Wind?
Is there car's going by him that will be effected by the Force of Doppler Effect?
Apr 09, 2013 | Cars & Trucks
What does a crankshaft do
A crank shaft converts the up and down motion of the pistons to rotary motion. It also transmits the power (force) produced by the pistons in a engine to useful rotary torque.
Dec 22, 2012 | 2001 Saturn L-Series
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
What is friction
A force that resists motion. Thus, in an example, if a block is resting on the floor, and the block is puched
across the floor, a force will resist the movement, this force is friction.
Mar 04, 2011 | Toys
Car mode - SUZUKI ESCUDO\r\n -NOMADE -V6 -Gear Transmition is Automatic *Problem is -once the gear handle is inserted to Drive mark and other mark for...
First check for low gearbox oil. With low oil the converter cannot 'spin' fluid properly and generate power.
It may also need the bands adjusting in the gearbox. These are the most common (maintenance issue) and cheapest fix.
Other problems can be a busted pump or valve body which are more costly to have replace.
Jan 18, 2011 | 1999 Suzuki Vitara
What is the basis for the classification of levers?
levers are graded as to the ratio of force needed to move a given weight.this is calculated from the fulcrum to the end of the lift point(upwards motion) then from the fulcrum to the end of the lever arm.(downwards motion)these clculations vary dependong on the lengths of (say)a crowbar.this being the simpilst of levers.
Nov 22, 2010 | 1999 Chevrolet Silverado 1500
My blackberry 8520 cure app error 523...
1. Install the software Desktop Manager
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader
3. Open Desktop Manager
4. Connect Curve 8520
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System
6. During the process, select YES to do a backup
7. The whole process should take about 1 hour
May 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Power switch is sitting crooked, half inside the computer. How do I take the back off to push it back out?
1. It looks you have pressed the Power button with force..thats why its gone inside!
2. There is no recommended solution! But you can try to push the button with little force and try to move it left-right or in circular motion! (No Warranty for this advice!) :(
3. If it don't works, contact your authorised service center for help!
tell me if it don't helps..tc! :)
Jan 05, 2010 | Toshiba Satellite A75-S229 Notebook
02 Mitsubishi Eclipse heater gets hot only when in motion
Does your engine temperature guage read normal? Have you checked your coolant level? This can be the result of a partially seized thermostat... there is also a valve in the heater core lines that can seize partially closed. As the engine speed increases, the water pump can force more water through the partially closed component.
Mar 04, 2009 | 2002 Mitsubishi Eclipse
iPhone Apps Logo
70 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
