Question about Garden
Lawn mower dies after it's warmed up and won't start unil it cools off.I replaced the air filter a spark plug. What could be roblem?
  • 376 Answers
SOURCE: Hello I have a Craftsman eager 1 Lawn Mower model
The breather hose has nothing to do with it not starting. It starts when you prime the carb and dies when that gas is used up. Being a Tecumseh. it's most likely the bowl nut/jet stopped up. Unscrew the bowl nut and clean it. Look cery carefully at the top of the threads. There is probably a very small hole there also and it will not run if it is not open.
Posted on Jun 20, 2009
Testimonial: "Carb kit was on the money installed it on8/20/09 Started and Runs fine"
wilsodfarm
  • 986 Answers
SOURCE: lawn mower won't start, it backfires when string
You need to pull your flywheel and replace the aluminum key
Posted on Aug 22, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
SOURCE: i have a ryobi lawn mower with a 6.5 hp motor. it
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
Posted on Jun 04, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My lawn push mower will
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 16, 2011
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Mower starts good but only runs 5 minutes befor stalling out and won't start again until cool. It idles OK when blade is NOT engaged. Cause? And how do you set the carb adjustment screws to max. p
No adjustment for carb on newer mowers. All mowers now have a low oil cutoff. Ensure oil is full. 30w oil. If any grey is observed vin oil drain all oil. Moisture in oil. Dump old oil out every 2 yrs and refill. Ensure spark pluf is clean and gapped correctly. Ensure air filter is clean. Replace spark plug and air filter each year. Always use Stabile in gas. Spray outside of carb with carb cleaner to ensure proper choke movement.
Sep 24, 2012 | Toro Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
First start is excellent when cold, will not restart again warm
It sounds as if your engine may be getting too hot. I suggest that you check under the covers and make sure that all the debris is cleaned out. These are air cooled engines and as such need to be kept relatively clear of debris, especially anywhere there are cooling fins.
May 09, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
May 01, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
