Question about Microsoft Windows 7 Ultimate for PC
Why cant i install windows updates-it shows error0x80040609
Uninstall windows Live Essentials
Below are the steps on how to uninstall Windows Live Essentials via CMD line parameter.
a. Go to Start ->All Programs ->Accessories
b. Right click onCommand Promptand select Run as Administrator
c. Run the following commands to uninstall Windows Live Essentials:
· (64 bit) "c:\program files (x86)\windows live\installer\wlarp.exe" /cleanup:all /q
· (32 bit) "c:\program files\windows live\installer\wlarp.exe" /cleanup:all /q
d. A dialog box shows status until uninstallation has completed
The uninstaller for Windows Live Essentials 2011 can also be downloaded
Posted on Aug 02, 2014
I had linux when i bought my hp compaq presario laptop.Then I installed windows 7 on it.I had my windows for3 years and didn,t had a problem till now.I updated windows and then when it restarted the grub...
Sounds like you may have installed windows alongside of linux after linux had been installed. This is not usually advised. If this is the case your most likely seeing windows boot loader instead of grub. If you did in fact fully replace with windows then the update may have two installations of windows on it. Either way I would recommend backing up data on hard drive (use a live cd to view data) and format hard drive and re-install Windows and if you had/want linux as well, install that after windows. If you can give me a little more info I can help you more.
Sep 03, 2013 | HP Computers & Internet
I purchased SOny NWZ-S544 Walkman. when i connect it to my laptop (Windows XP OP) it will not show up unlike other device, so i cant access it through my laptop pls help
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope I could help you.
Thanks.
gylacz
Aug 01, 2011 | Sony NWZ-S544 Digital Media Player
My asus crw 5224a is inoperble driver update cant
Because you are trying to install the wrong driver.
Go do windows update and windows will install the correct driver for you, this will work on windows xp, vista and windows 7 only, you did no state your OS.
Hope this helps
Mar 13, 2010 | ASUS CRW 5224A CD-RW Burner
I CANT INSTALL WINDOWS LIVE MESSENGER FOR WINDOW XP
Update to Service Pack 3.
http://www.windowsupdate.com
Keep going back until you get all updates installed, then try again.
Mar 04, 2010 | Microsoft Windows Live Messanger
I cant intall update
if this is a failed microsoft update,write down the number or title,check add remove programs with the show updates box checked,if you see it installed then uninstall it an then check for new updates to see if it works,otherwise,go to microsoft update,view update history ,look for failed update ,click on it and follow the help links,usually end up at another update that needs to be installed first,just disableing microsoft updates,and switching back to windows update fixes update problems,and vice-versa
Oct 22, 2009 | Toshiba Satellite Pro L300 Notebook
Cant download
hELLO THERE:
Please go to www.radarsync.com
this is a totally free driver utillity that will help you find and install the driver for the device once it is downloaded just select the free option than let it scan the computer and a listt of drivers that need updating will show up
next click on the details colum it will show the avail. drivers then just click on the more info area and it will show your current version and the version that is the updated version than click on history and the driver will be there for your operating system now just click on download and you are set it will tell you that the driver is ready for install just click on install and it will install from there ok?
hope this helps
best regards michaell
Sep 10, 2009 | Microsoft Windows Vista Ultimate Edition
DSL200
Do what you need most. You have to choose yourself whether you require DSL200 or SP3. I can only tell you how to remove SP3 from your PC. Goto start button control panel, add remove programs, Change or remove programes and on top select show updates check box in the list below you will fine windows update Windows XP service pack 3 just click on remove. Further, once you are done with installing your DSL you can once more try installing service pack 3 and see wether both work in harmony or not.
Jul 25, 2009 | D-Link DSL 200 (DSL-200) Modem
IPod shuffle Second Gen problem
Apple recommends that iTunes customers using Windows Vista upgrade to iTunes 7.2 or later. If you are using an iPod with iTunes on Windows Vista, please review the important information in Knowledge Base document
Ejecting iPod using Windows Explorer on Windows Vista may corrupt iPod
Issue
Some customers may see the following message when connecting an iPod to iTunes 7.2 or later on a computer running Windows Vista.
Solution
Microsoft has released an update for Windows Vista that addresses a situation where ejecting iPod from Windows Explorer or by using the "Safely Remove Hardware" feature in Windows Vista could corrupt your iPod. Apple recommends Windows Vista customers who own an iPod install this software update. For information on how to install this Microsoft hot fix, refer to the "Update your software" section below. Tip: iPod can always be ejected safely by choosing Eject iPod from the Controls menu within iTunes.
Microsoft has made this Update for Windows Vista (KB936824) available via Windows Update as well as a separate download package. To download this update via Windows Update follow the steps below:
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, select Check for updates in the Security section. If the Control Panel is in Classic view, open Windows Update.
  3. Click the View available updates link and be sure that Update for Windows Vista (KB936824) is checked.
  4. Click Install.
Sep 15, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Microsoft Windows 7 Ultimate for PC Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
