Question about Brother Mfc-j280w Mfcj280w Wireless Aio Color Inkjet Printer
Take apart brother mfc-j280w
Need to clean
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
  • 526 Answers
SOURCE: MFC 215C, mfc 215c erorr 46
most likely your flush box is full of ink, the pads will need to be replaced by a service center.
Posted on Apr 20, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC-420cn Message appears,
Hi you can try this is for your error and please call back and let us know if it worked for you so others can do the same.Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the Best: Pineworks
Posted on Jan 30, 2010
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Posted on Apr 30, 2010
FixinFax
  • 3085 Answers
SOURCE: MFC-8440 All-In-One Laser Printer: how to clean the drum for Brother MFC-8440...
Move the blue slider on top of the drum unit 10 times back and forth.
Posted on May 21, 2010
When I try to scan, I get "memory full"
Try scanning at a lower resolution. Scanning an A4 Photo on highest resolution is likely to give the printer a memory meltdown causing the Memory Full message.
Scan at 1200x1200 DPI instead of 1200x2400 DPI. Depending on what you are using the scan for you can even bring it down further. if it is just to facebook or e-mail pictures then 600x600 is fine.
Oct 24, 2014 | Brother MFC-J280W Compact Inkjet...
Brother mfc-j280w wont work
reset the printer if any error displayed
Mar 19, 2012 | Office Equipment & Supplies
I TOOK APART A BROTHER MFC-3240C PRINTER AND CLEANED THE HEAD NOW IT KEEPS SAYING PAPER JAM PUT THERE IS NO JAM.WHERE IS THE PAPER JAM SENSOR LOCATED AT
well have you cleaned the head manually or by using the software thru the pc. if you have done so by hand it may cause aproblem try cleaning using the software and see id that helps.
Oct 03, 2010 | Brother MFC-3240C All-In-One InkJet...
Where is the absober pad to clean on the Brother MFC-3240c
Hi there
There no easy way the printers are been made this way so you take them to the shop, but if you are handy with your hands and know what you are doing then you will need to take all apart and take out the ink pads inside the printer and clean them up make sure they nice dry when put back in, then you are going to need a program that you can find on the internet it will be called waste reset tools, or your printer will not work even after you done the clean out.
May 08, 2010 | Brother MFC-3240C All-In-One InkJet...
Clean brother encoder strip
The encoder strip is barely visible thru the top in front of the printhead, if you can see it without taking all apart, you use a Q-tip just damp with water and wipe each side as far as you can reach.
Oct 21, 2009 | Brother MFC-640CW All-In-One InkJet...
I have air bubbles in the black ink feed tube on my brother mfc 210 c printer and it won't print. I have run the cleaning problem several times but it didn't help. The color inks print fine.
You've almost answered your own question! Try ruling out the ink cart first (preferrably with an Original Brother cart). If the cleaning cycle does not resolve it then it's really an engineer job.
Not much else you can do, unless you know how to take apart the machine.
Jun 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother Mfc-j280w Mfcj280w Wireless Aio Color Inkjet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
