Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
Battery for older model a5000 sump pump - Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
Why is petrol getting into oil sump
An older model engine with mechanical pump could have a bad diaphragm leaking gas into the oil. Newer engines with electric in tank pumps with gas in the oil are probably running way too rich or have piston ring sealing issues.
Nov 16, 2015 | Cars & Trucks
WHY THE PUMP WONT TURN ON,
It is possible that the pump itself has failed.
May 08, 2014 | Simer A5000 Ace In The Hole Battery Back...
The flood light stays on and the pump will not work
Can anyone help? My Simer backup sump pump flood light is on continuously. All the rest of the lights seem to be working fine and the pump looks like it is in working order. When I toggle the lood light button it just gets brighter. tHANKS...SCOTT!
Jan 14, 2013 | Simer A5000 Ace In The Hole Battery Back...
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Hope this helped you.
Jun 24, 2011 | Goldstar Dehumidifiers
I just bought a Model A5000 battery back-up pump and the installer never left me an owners manual & installation instructions. he installed it, but claims their was no manual in box. How do I get one?
Contacting the manufacturer is the easiest way to get one. You may also be able to get one from the point of purchase (ie. Lowes, or Home Depot).
Good Luck,
Zim
Apr 27, 2011 | Plumbing
The f-05 is flashing up on the LCD screen and washer won't spin just stops.model is wd860
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
Apr 25, 2011 | Hotpoint Washing Machines
My sump pump fails to work during big rains. If I
if you dont know how old it is and think it is really old replace floods are never fun
May 14, 2009 | Plumbing
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
75 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Boyet Soriano
Boyet Soriano
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
