Question about Brother HL 5250DN Laser Printer
How do i get a meter reading on Brother HL 5250DN?
printech
  • 159 Answers
SOURCE: Brother HL-5250DN
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Posted on Mar 27, 2008
SOURCE: WHEN PAPER FEEDS THROUGH PRINTER COMES OUT
Try these - is paper dry?
Are you using good quality (80 gsm minimum) paper?
Are the fuser rollers (open back of printer, pull down inner paper guide using projecting lugs) in good shape?
Is there any paper debris in the paper path either before the laser unit or on the final path (look carefully at the little paper separator fingers) that is impeding the paper run at one side?
Does the bypass tray give good or bad results? - if good, look for paper debris in the initial feed path.
Are any flexible plastic guides pulled out of shape to face back up the paper path - often caused by pulling a misfeed out backwards?
I find that paper scraps in the initial feed path can be impossible to see, so I have a piece of laminated paper to push through the feed path. It often finds bits I couldn't see.
Posted on Mar 05, 2009
SOURCE: I want to find the MAC address on a Brother
Go to Printers and Faxes.
Right click on the printer and select Properties.
Toward the bottom, click on Printing Preferences...
Click on the Support tab.
Click on Print Settings.
This should give you three pages. The third page has the network settings including Ethernet/MAC address.
Posted on Apr 06, 2009
SOURCE: brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
rolf@edeborg.se
Posted on Mar 10, 2010
  • 20 Answers
SOURCE: I've installed a new drum AND a new toner
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Posted on Mar 05, 2011
Driver printer brother hl-5250dn
Go to this link and select your operating system, select language, and click the search button.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Hope this helps.
Aug 09, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN printer on Linux operating system
you have to set it in the printer settings to do that
Mar 05, 2009 | Brother HL 5250DN Laser Printer
Two sides printing Brother HL-5250DN
You can change it from printer properties.
Jan 16, 2009 | Brother HL 5250DN Laser Printer
HL-5250dn ona Bonjour network will not work with Leopard
have you already tried reinstalling the driver of the printer?
Oct 21, 2008 | Brother HL 5250DN Laser Printer
Brother is totally fucked up under Leopard, found so far no chance to fix it.  Brother's own printer drivers are 10.4 only -- lame
Feb 24, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
56 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
