Question about NEC Office Equipment & Supplies
Why does an nec projector image dims after 15 seconds?
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
  • 3422 Answers
SOURCE: Projection is so dim
Click HERE for the user manual.
I hope this helps.
Goodluck,
Please don't forghet to rate the solution
Posted on Mar 22, 2008
Marrie
  • 563 Answers
SOURCE: nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Posted on Apr 10, 2008
Try turning up the brightness?
Posted on Apr 30, 2008
  • 14 Answers
SOURCE: proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Posted on Sep 14, 2008
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
I have three NEC LT 245 projetors, one of them is dim compared to the others even though all setting are the same. How can I correct this?
check the lamp of the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause dim image.
May 18, 2011 | NEC LT245 Multimedia Projector
How you can fix blue light problem on NEC projector? Shahid
what does the blue light problem look like on the screen. is it all over the screen, or small dots, or a dim haze etc?
Apr 19, 2011 | NEC MT1075 Multimedia Projector
I work for a school district and one of our projectors is projecting a dim image. We have replaced with a brand new bulb and still have the same problem, however after changing the lamp there were pink...
You will possibly find that there is dust on the LCD units plus it sound as if the filters may have been blocked for a while, causing damage to the blus LCD unit giving a dull picture effect.
This is not repairable unless a new optical block is fitted.
Dec 17, 2010 | NEC VT491 LCD Projector
The nec vt575 shows an image on the projector but not from laptop
this is very simple, its just a matter of a bios upgrade for your laptop
Mar 23, 2010 | NEC VT575 Multimedia Projector
Sometimes the NP50 lamp will come on, sometimes it won't. Sometimes it seems like the color out-put isn't sharp or correct, like a faded picture. It's like something is wrong with the color. So it seems...
projectors really don't like hot and humid. they love cool and dry. if the colorwheel is failing, the lamp wouldn't come on. humidity+dust+intense lamp heat=coated components. such as the colorwheel glass, which is clear and coloered. fried dust will cause dimness. you'd have to send it in to nec.
Aug 20, 2009 | NEC NP50 Projector
Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Mar 23, 2009 | NEC VT676 Multimedia Projector
New lamp but image is dim
This usually means that there is some contamination in the light path. Since many of the mirrors and lenses must be carefully aligned, it is not recommended to have the homeowner dis-assemble +/or clean these. This unit should be sent in for serive, requesting a complete clean and alighment. The unit will be cleaned, any filters changed and the convergence checked.
Dan
Feb 02, 2009 | NEC VT460 Multimedia Projector
NEC DATA Projector
A trapezoid can be corrected using the "keystone" feature. This is used when your projector is located above or below some angle other than 90° to the centre of the screen.
As for the second tone, that may correct with the keystone.
Sep 17, 2008 | NEC VT460 Multimedia Projector
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
24 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
