Question about CPR Aquatic CPR CS150 Overflow Box - 1600 GPH
Im having issues with my tank overflowing
I have the cs150 overflow box by cpr. my return pump is the mag18. Recently I have been having trouble keeping my water levels stable. Either my tank wants to overflow or my sump wants to overflow and I don't know how to correct this problem.
  • 2,760 Answers
This device is a siphon overflow , care will need to be given in keeping it clean and sealed well or siphon will be lost and yes tank can overflow ive been told a small bubbler in middle section as a tickler will keep siphon going better , im not a great fan of siphon type over flows , but if you have the means a hole type overflow is far superior to this ,way less probelms
Posted on May 28, 2016
Can a water pump make water to return to the water bottle
If the engine overheats from a thermostat
stuck closed or bad head gasket
Aug 10, 2013 | Cars & Trucks
2009 hyundai elantra gas tank engine light
Buy a new tank cap. Fill ur tank slower. Inspect the fill hose for akink or damage. And looknst the overflow vent line. Fuel caps keep air out they do need replacing once and a while. Ur take vents at the cap sounds like ur cap is not venting or ur return over flow line has issues try a new cap first. Then go deeper if issue still there chk the top of the tank where the gauge sending unit is. Etc etc.
Feb 10, 2018 | Cars & Trucks
Overflow tank not storing coolant.
Don't jump the gun and replace the head gaskets like the guy recommended...you need to have a technician look at it...can be a minor issue or something totally different. I had the problem with my stratus and paid tons of money to do the heads...never solved the issue and heads were done right. Its was blockage with in the coolant system and was discovered til my water pump went out.
Mar 05, 2013 | 1991 kawasaki ZZR 250
Im switching gas from rear tank to front tank or from front to back and it is causing overflow
sounds like the switching valve for the gas to draw out one tank first then the other tank is bad and needs replacing.this can cause gas to be pumped into the other tank causing it to overflow.
Apr 20, 2011 | Ford F-150 Cars & Trucks
When I refuel, gas would overflow even after the pump has automatically clicked off. This happens both when I hold the pump handle manually and when it is locked in place.
check in the throat of the filler neck and see if the overflow tube is blocked small hole in the neck that allows overflow of gas to bleed down like the way your bathtub works when it gets to full check the passage if its clear or the hose from the neck to the tank
Jan 10, 2011 | Jeep Wrangler Cars & Trucks
'94 Camaro Over Heating
Possible problems; water pump, impellers may deteriorate and therefore have low circulation.. Clogged passages, and even the mixture of the coolant.
Sep 10, 2009 | 1994 Chevrolet Camaro
Gas leaking out where you fill the front tank
You probably have a defective fuel-tank selector valve. Its located on the left frame rail, halfway down. While the vehicle is running, tank"A" is pumping fuel to the engine, while tank "B" is getting the unneeded fuel that is returning from the engine. Thats why it is overflowing.
Jun 18, 2009 | 1990 Ford F150
Gas tank over flows when filling up at the pump
This is the same issues I'm having. Is there any answer to this?
Mar 28, 2009 | 2005 Nissan Sentra
Gas overflows when fillingtank.
This sounds like the gas tank vent pipe is obstructed.
Dec 10, 2008 | 2005 Jeep Liberty
CPR Aquatic CPR CS150 Overflow Box - 1600 GPH Logo
329 people viewed this question
Top CPR Aquatic Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a CPR Aquatic Fish Expert? Answer questions, earn points and help others
