Question about Garden
I need a manual for home maintenance of my poulon pro mower
  • Rob Carpenter May 11, 2010
    You can go to this sight and input your model and download the manual for your mower.http://www.poulan.com/poulanpro/manualSe... I hope this helps you. Please leave good rating. If you need any more help let me know.
2 Suggested Answers
SOURCE: Briggs & Stratton Poulon Pro 600 Series Cuts Out After a Min
Water in the carb bowl. Primer charge is gas...what the main jet draws is water! Tipping backwards lets the water move away from main jet pickup and clean fuel to enter engine.
Drain the tank. Then the carb and fuel line. Then check your gas can for watery fuel. *(dump it into a large plastic bowl and look to see if there is a layer of water on the bottom. If you shake up the fuel before you pour it off you will see cloudy liquid if there is water in it).
That should do it.
Posted on Jul 18, 2010
What kind of oil does a poulon pro 550EX law mower take
Poulan Pro Lawn Mower Engine Oil 30W 20oz PP60019
Nov 10, 2016 | Garden
Will a poulon pro 550 lawn mower work if it has no oil
Yes, until it blows up or engine seizes up. All depends on how well you like the lawn mower.
What causes a Poulon Pro riding mower with a 19.5 HP Briggs to shut down after only running for about 15 minutes?
Will it start rite back up?
Check to see if you have a low oil sensor,
Sometimes the oil sensor wills me it shut off when it's a little low on oil.
May 17, 2015 | Poulan Pro 19.5HP Lawn Tractor 960420123
Poulon 96012002000
it is normal for the wheel with the least resistance to spin riding lawn mowers are not driven by both wheels you would tear up the lawn on turns
Jun 09, 2012 | Garden
I have a Poulon Pro (yellow) PR550N22SH. There IS no visible oil drain on it - neither at the base nor underneath. Any ideas where it is on this piece of junk?
Unfortunately, on some of these machines (even my Honda), you have to actually dump the oil out through the fill spout. I just get my mower sideways on a slight hill and put the oil pan downhill from it then gently roll it on its side and dump it out. Tip it back up and over a few times and let it drain well before you add the new oil. If you put synthetic oil in there, it'll last you longer between changes.
Oct 22, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Poulon pro 18" smoking
The only way a two stroke can smoke is either it is running far too rich ( possible blocked air filter ) or there is too much or incorrect oil in the fuel, if the oil tank for the chain is sepereted from the crankcase by a gasket, it maybe the gasket leaking and allowing chain oil into the crankcase.
Sep 10, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
New pp208e24 poulon pro snowblower... keeps leaking oil , there was pool of oil on the bottom of carton when opened. added more oil but oil leaks continues.
Hi yoshtak, I wouldn't try fixing it. Might void warranty, take it back. If they don't make it right we'll go from there.
Dec 22, 2010 | Poulan Garden
That should do it.
Jul 17, 2010 | Briggs & Stratton Garden
Poulon-Pro leaf blower manual
If you know your model number (i.e EVB160 etc) you can use this link:
http://www.poulanpro.com/node4043.aspx
enter your model number and download it.
If you do not know your model number
click on products same link, then click on blowers (not snow throwers) find your model then go back to the users manual download.
Thanks for using fixya.
Feb 14, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
